Author Topic: Auto trans shifter linkage.....what am I missing?  (Read 6481 times)
Offline xtremjeepn
« on: March 09, 2008, 07:32:13 pm »
There is a shift rod and spring from the transmission to the frame. It fits really lose and the shift rod and spring slip right through the frame mount tab/hole.
Does anyone have a parts diagram or picture of what I am missing?  And where can I find the parts???
Cole
Restomod Crew Cab Short box on 37"s
Re: Auto trans shifter linkage.....what am I missing?
« Reply #1 on: March 09, 2008, 07:35:55 pm »
There is supposed to be a bushing in there. If your bushing is gone you can just make one out of rubber or nylon. A grommet or a few nylon drain plug gaskets will work.
Offline Monzter
    • Monzter Kuztomz
« Reply #2 on: March 13, 2008, 10:27:57 am »
You can use a 3/8" or 10mm flat washer to keep the spring in. IF you want to fix it like GM built it go to the local Chevy/GMC dealer or local transmission shop & tell them you want a TH350 / TH400 cross shaft shifter linkage to frame grommet, shouldn't cost more than a buck or two.
Offline xtremjeepn
« Reply #3 on: March 13, 2008, 11:01:19 am »
Thanks. I will try the washer first and see how well it works.  (truck is WAY far from original)
Cole
« Reply #4 on: March 13, 2008, 09:22:07 pm »
My blazer has a flat washer and a lug nut in the cup for a bushing! ::)
Offline Monzter
    • Monzter Kuztomz
« Reply #5 on: March 13, 2008, 10:15:22 pm »
Never thought of an Acorn lug nut, that would work pretty well.
« Reply #6 on: March 14, 2008, 07:30:55 am »
It was a temporary trail fix that has been in there for about 8 years now!
Offline xtremjeepn
« Reply #7 on: March 14, 2008, 05:36:16 pm »
Hmmm.......Ihave a BUNCH of extras of those laying around. I will give that a try maybe.
Cole
