Author Topic: GOT A NEW TPI MOTOR!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!  (Read 13738 times)
Offline 85MudMonster
« on: March 09, 2008, 09:11:00 pm »
I'm wondering what I should do...I have an Olds 350 that I know can easily make 350ft/lbs of torque. I also am getting a TPI 350 from out of a camaro, I don't know how much torque it can make but the fuel economy would be good. What I want is an engine that will make 375ft/lbs of torque @ 2000rpm or more and like 300hp @ 3500 or 4000rpm. Which option would be better to work off of, the big bore short stroke Olds motor or the smaller bore longer stroke chevy fuel injected motor?
« Last Edit: March 24, 2008, 09:06:01 am by 85MudMonster »
Dan
85 Chevy K10 - 408 BBC from a 71 Chevelle SS, TH350, NP208, 33" Mastercraft Courser M/T
Re: High Torque Low RPM motor options....
« Reply #1 on: March 09, 2008, 09:15:26 pm »
You'll get better cheaper results from the SBC
The olds engines were relatively low compression smog friendly gas guzzlers. They can be built but cost more $....
I just built one for my buddy
« Reply #2 on: March 09, 2008, 11:08:19 pm »
yeah, but can I get a high torque low rpm engine out of that TPI SBC? I mean will it do 375 or 400 ft/lbs at say like 1800-2000rpm?
Dan
« Reply #3 on: March 10, 2008, 06:30:55 am »
If you want something that peaks torque at low RPMS you should be looking at a diesel. But why is your main goal peak torque at low RPM? And yes you can build your engine to promote higher torque at lower RPM.
« Reply #4 on: March 10, 2008, 09:25:29 am »
I'd like a diesel, but it's too much for me just to get the engine. I mean I'm getting the TPI SBC for $100. I want lots of torque so that with the doubler and the 4.96 gears it will go over or through anything.
Dan
« Reply #5 on: March 10, 2008, 10:07:45 am »
well with a doubler and 4.96 gears you shouldn't have a problem
« Reply #6 on: March 10, 2008, 10:51:47 am »
yeah, and I'm gonna be running 40" tires as well. I'm gonna change out the 10 bolt axles for some 14 bolt ones, although I'd like to get some 2.5 ton planetary axles off of an old military truck, but their hard to find down here. I'm getting a 6" lift and that TPI SBC for $300 dollars though. And since I'm getting the SBC and I have a SBO I was just wondering if the Chevy can be built to make torque like I know the Olds can. And since you said it can, I think I'll be using the Chevy since it will get better fuel economy than a Carburated motor will.
Dan
« Reply #7 on: March 10, 2008, 11:50:05 am »
TPI's are make for low end power, the were designed with that in mind.  Generally they start falling off around 4800rpms.  The runner design promotes torque also.
I would go with a TPI over the Olds, just don't start going off the deep end with cams and such.  The TPI peaked at 245hp and 350lb/ft in 1991
the one listed here: http://www.superchevy.com/technical/engines_drivetrain/induction_poweradders/sucp_0703_stealth_tpi_induction/index.html
had a CompCam 270HR cam and headers and made 327hp and 397lb/ft.
« Reply #8 on: March 10, 2008, 02:08:25 pm »
that is almost the perfect set-up. I'd rather the torque come in a bit sooner than 2500rpm, but I think I can work with that.
« Last Edit: March 10, 2008, 03:35:20 pm by 85MudMonster »
Dan
« Reply #9 on: March 10, 2008, 03:16:52 pm »
You can put that in the For sale forum an I can remove it from here.
Offline 76_Scottsdale
  • I'd rather push my Chevy than drive a Ford
« Reply #10 on: March 11, 2008, 11:29:42 am »
I was just about ot site that article went I saw you already did  :P
That was a great article, made me true believer in TPI. I'd rather find a system like that and do the mods that they did than buy a brand new EFI system.
1976 Scottsdale K20
350 C.I.D.
700R4
NP205
2 1/2" Lift
305/70/R16 BFG MT
True Dual 3" Flowmaster 40 Series Exhaust
« Reply #11 on: March 24, 2008, 09:05:27 am »
I just Got the TPI 350 block, rotating assembly, and vortec heads yesterday for $50!!! What numbers do I need in order to find out what block and heads these are so I can find the specifications on them? Also where is a good place to find specifications on GM engine parts? Thanks guys.
Dan
Re: GOT A NEW TPI MOTOR!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
« Reply #12 on: March 24, 2008, 11:33:32 am »
I use www.nastyz28.com for looking up GM numbers, or I go to the dealership...
Offline bigkountry
« Reply #13 on: March 24, 2008, 02:46:30 pm »
Hers a good one as well.
http://www.mortec.com/
Offline joesgarage71
  • Wrench
« Reply #14 on: March 25, 2008, 09:31:59 am »
 I just ordered this book last night for the TBI project I'm doing.Putting a 93 TBI in my 78 trail truck. TPI/TBI Engine swaping By Mike Knell ISBN # 096266720X
 If your doing a swap I'd get everything from that camaro if I was you. It will save a lot of cussing later.
 Steve
« Last Edit: March 26, 2008, 07:21:12 am by joesgarage71 »
