Author Topic: Rear slider Weatherstripping  (Read 7504 times)
Offline JJSZABO
« on: March 13, 2008, 11:07:54 am »
I have the GM rear slider that I need to install.  I was told that the rubber seal for the original sliding window is no longer available.  Has anyone replaced their single piece glass with a slider and what gasket did you use?  Thanks
Jeff
Jeff
86 Chevy C-10
350, TH400
Offline Dragon
Re: Rear slider Weatherstripping
« Reply #1 on: March 13, 2008, 12:05:35 pm »
No Longer Available through GM Yes, but should be available through any well stocked Auto Glass Shop(Speedy Auto Glass/Safelite/ETC)....
Dragon
08 Magnum-New Toy
96 Caprice 9C1-Who Knows
96 GMC ECLWB & 92 Chevy ECLWB
Offline JJSZABO
« Reply #2 on: March 13, 2008, 12:10:53 pm »
No...already checked local dealers, they say no also. :'(
Well, to be honest I only called safetyglass and banner glass - I'll keep checking.
Jeff
86 Chevy C-10
350, TH400
« Reply #3 on: March 13, 2008, 01:59:21 pm »
are you talking about the gasket for the complete glass?  It is the same if it is a GM slider.
Offline JJSZABO
« Reply #4 on: March 13, 2008, 02:21:45 pm »
Yes Chris, so ANY aftermarket rubber seal will work?
Jeff
86 Chevy C-10
350, TH400
« Reply #5 on: March 13, 2008, 02:57:53 pm »
Yes.  IF it is a GM supplied slider.  I removed my Slider that came on my 87 and replaced it with the same gasket.  If the current one has a small area that a glass will go into you are set to get just a regular glass gasket.  Got a pic?
Offline JJSZABO
« Reply #6 on: March 13, 2008, 07:49:23 pm »
This is the inside - it says PRESTIGE on the lock:
This is the outside:
This is the flange:
Thanks for your help Chris ;D
Jeff
86 Chevy C-10
350, TH400
« Reply #7 on: March 14, 2008, 10:19:38 am »
It's thin like the glass that came out, just get a regular gasket.
Offline JJSZABO
« Reply #8 on: March 14, 2008, 04:00:08 pm »
OK thanks ;D
Jeff
86 Chevy C-10
350, TH400
