Author Topic: Changing spark plugs with headers.  (Read 26478 times)
Offline txtj79
  • 1980 Chevy C-10 SWB
« on: March 15, 2008, 05:22:05 pm »
The previous owner installed headers on this 350.  The problem is it needs new plugs, but one of the headers is blocking access to one of the spark plugs.  I was able to change the other 7.  The header pipe is just enough in the way that I can't put the socket on the plug straight.  I swear, if I had another quarter of an inch of room, I could make it work.  Does anyone have any tips or tricks?
Thanks,
T.J.
Re: Changing spark plugs with headers.
« Reply #1 on: March 15, 2008, 05:23:32 pm »
did you try a 5/8" wrench or stubby wrench?
Offline Bitzer!
  • Smiles per gallon
« Reply #2 on: March 15, 2008, 05:50:46 pm »
Dunno if you guys have them there but try a short extention bar with a "wobbly" end?
1979 GMC CrewCab  C20 1t
« Reply #3 on: March 15, 2008, 05:59:15 pm »
All my trucks with headers have a couple that need to use a 5/8" wrench for.
Offline smoke
« Reply #4 on: March 15, 2008, 09:30:42 pm »
x2 on the 5/8 wrench
Offline Toolmaster
« Reply #5 on: March 15, 2008, 09:57:08 pm »
On the 76 I had. I made one fit by bending,cutting and some welding with a crescent wrench attached for
leverage. I will see if I still got it and snap a photo of it.
Offline 77c15
  • combustion=suck, squeeze, bang, blow
    • My cardomain site...
« Reply #6 on: March 16, 2008, 06:16:05 am »
Must be some nice headers. The headers on mine and my dad's are from Summit and they block 3 of the spark plugs. An old 5/8 wrench bent in an S works great, though.
Offline loudnlow87
« Reply #7 on: March 16, 2008, 03:08:37 pm »
why not tap the header tube in a little?
stock really sucks
Offline 77c15
« Reply #8 on: March 17, 2008, 10:42:52 am »
These are cheap Summit brand headers ($90!) and my dad has already went through a set from warpage.
Offline Bowtie Bomber
  • Rolling American Iron
« Reply #9 on: March 17, 2008, 12:01:03 pm »
Welcome to the joys of owning headers.  ::)
Yeah we have those as well. They're called universal joints.
What I'd do is just get a ratchet box end wrench and take out the spark plug. Heck, just get it loose, you should be able to twist it out with your fingures after you loosen it a couple turns.
My truck is my flying fortress, the road is my sky, and Toyota's are the enemy bunkers that need a busting.
Offline txtj79
« Reply #10 on: March 17, 2008, 12:46:04 pm »
Well, I've had some luck.  I was able to get it out because the tip busted off and I could fit a short socket in there.  But now, I can't seem to fit a wrench in there to tighten up the new plug.  I may have to unbolt the header in the long run, but first I'm gonna see if I can find some type of wrench that will work.
Thanks for all the help.
-T.J.
Offline monte85
« Reply #11 on: March 17, 2008, 01:13:42 pm »
they do make extentions that are not universal joints, but have an end almost like a ball-end hex key. it allows the socket to pivot on the extention, without the added length a universal joint gives you. i think they even call them wobble end extentions.
"Of my friend, I can only say this: of all the souls I have encountered in my travels, his was the most... human."
« Reply #12 on: March 17, 2008, 02:30:01 pm »
Sears sells offset 5/8" wrenches or just heat and bend an old crappy 5/8". I have so many home made tools from over the years  ;D
« Reply #13 on: March 17, 2008, 03:47:11 pm »
I have never had a problem using a decent 5/8" combonation wrench. snug it with the open end, then give it the final grunt with the box end.
Offline txtj79
« Reply #14 on: March 17, 2008, 05:50:20 pm »
My neighbor had the perfect offset wrench.  I used a short piece of stiff hose to thread the spark plug into the hole.  Then the neighbor's wrench to snug it up.
-T.J.
