Author Topic: tv cable.weird shift's  (Read 10707 times)
Offline smoke
« on: March 15, 2008, 09:08:36 pm »
have a 86 gmc with 350/700r4.shifts late when cruising and early and not very firm when wot.is it to tight or loose?won't self adjust.or do i need a new one?
Re: tv cable.weird shift's
« Reply #1 on: March 15, 2008, 09:14:02 pm »
tighten up the cable. Depress the tab and push the plunger toward the firewall.
Offline smoke
« Reply #2 on: March 15, 2008, 09:18:04 pm »
thanks i will try that.also won't shift into overdrive?maybe time to change filter and see if that helps at all.truck was setting for about a year.
Offline smoke
« Reply #3 on: March 16, 2008, 09:19:58 am »
i pushed it all the way in.and it acts better but mite need more.do these stretch over time?
« Reply #4 on: March 16, 2008, 09:51:02 am »
have you changed your carb? is there slack in the cable with the throttle closed?
Offline smoke
« Reply #5 on: March 16, 2008, 07:08:28 pm »
i just put the motor in but it is a quadrajet on it.and there is some slack with throttle closed.is it susposed to be tight?thanks for the help
« Reply #6 on: March 16, 2008, 07:09:44 pm »
if you disconnect the cable and pull on it is there spring tension on it?
Offline smoke
« Reply #7 on: March 16, 2008, 07:18:00 pm »
yes there is tension.and with it all the way towards the cab.you can move it 1/8to1/4in before it pulls out the slack.and moves the cable.
« Reply #8 on: March 16, 2008, 07:39:54 pm »
If you hold the throttle wide open how much more cable can you pull?
Offline smoke
« Reply #9 on: March 16, 2008, 07:53:11 pm »
none actually it was keeping my carb from opening all the way.how much should there be?there is another hole behind and just barely higher.should it be in that one?i haven't moved it.it's where it was when i got the motor.and it won't self adjust.
Offline 76_Scottsdale
  • I'd rather push my Chevy than drive a Ford
« Reply #10 on: March 16, 2008, 08:03:03 pm »
If it does't self adjust then the ratcheting mechanism is busted. I'd just order a new one and it'll work like new.
1976 Scottsdale K20
350 C.I.D.
700R4
NP205
2 1/2" Lift
305/70/R16 BFG MT
True Dual 3" Flowmaster 40 Series Exhaust
« Reply #11 on: March 16, 2008, 08:06:24 pm »
If it's too tight you can manually back it off a few clicks, however this won't help with your early shift. If it's still shifting too soon with the TV cable properly adjusted I'd check the governer valve and see if it's sticking.
Offline smoke
« Reply #12 on: March 16, 2008, 08:10:09 pm »
is that the one on the side?under the round cover?how does it come off?would a new one fix it?if so i will order one.
« Last Edit: March 16, 2008, 08:12:17 pm by smoke »
Offline smoke
« Reply #13 on: March 16, 2008, 08:11:18 pm »
and thanks for all the help!!it is drivable but this kind of stuff really bugs me.want it to be perfect.
« Reply #14 on: March 16, 2008, 08:13:08 pm »
yeah pop the cover off and pull the valve out. Check to make sure the springs are there and that the valve moves freely inside it's bore.
