Author Topic: PICs - I put 6x9s in factory rear corner brackets  (Read 15555 times)
Offline d stroud
    • Our Cars
« on: March 15, 2008, 11:30:38 pm »
It was kinda easy actually.
First, you've gotta swap sides with the brackets.  The right side will go on the left and vise versa.
I used the speaker cover as a template to cut out the existing bracket.  I used a dremel tool with a cut-off wheel.
Here are the brackets cut out to fit the 6x9's
Notice that I have flattened out the bottom bracket mount and have twisted it slightly.  You will see why shortly.
The cover required a little massaging to fit down over the speaker.
Here they are with the speakers mounted
And then mounted in the truck.  Notice how the bottom mount goes now.  You can put a screw in it now, but, after I installed the top screws I don't think I really need to. On each side, one of the top mounting tabs lined up with the factory hole and i had to drill one hole on each side.
Almost looks like it came from the factory like that.  It sounds very good too.  Now just gotta get my sub box built for my Kenwood sub and she should be good to go.
I know I didn't go into a lot of detail, so, if anybody has any questions, I'll be glad to try to help you.
« Last Edit: March 16, 2008, 12:21:31 am by d stroud »
Our Family Muscle Site
Yeah, Its got a Hemi...Just sucked one down the carb a few blocks back.
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
Re: PICs - I put 6x9s in factory rear corner brackets
« Reply #1 on: March 16, 2008, 04:38:47 pm »
I've been wondering how that mod would look.  I'll be doing it to my78 very soon seeing how good yours came out.  Great job!
Offline red4wd
« Reply #2 on: March 16, 2008, 04:54:49 pm »
20 years ago I had a set of aftermarket brackets for 6x9's...while my truck sat for several years all the stereo stuff disappeard out of it including the brackets.
That install looks good.
Offline Swims350
    • Cars and trucks
« Reply #3 on: March 16, 2008, 11:21:23 pm »
I think it looks good real good.
They do make 4x10 to 6x9 adapters though still yet.
www.cardomain.com/id/benwa454
Offline bigblock73
  • Yeller
« Reply #4 on: March 17, 2008, 08:31:39 pm »
You did a good job, turned out nice.
I made a set of 6x9 brackets...will have more made by the end of the week, and for sale shortly thereafter.
Jeff
'73 swb 2wd
73-87.com
Offline CruzinHigh
  • Chevy 4 life
« Reply #5 on: March 18, 2008, 10:44:29 am »
Any pics with your custom brackets installed bigblock?
Nice job with your custom install d stroud!  Thanks for the photos.
Mike Carter
1986 Chevy K-10 4x4
Offline okuma
« Reply #6 on: March 30, 2008, 10:38:23 am »
bigblock how much do you want for a set?
post pics of brackets installed.......  ;)
Offline Redneckchevy
    • Photo Bucket
« Reply #7 on: March 30, 2008, 10:44:22 am »
yea i would like a set when u get done.....Right now i got boxes in the back of my seat...And im so tall i need the seat pushed all the way back..SO it muffels the sound alot..
Offline bigblock73
  • Yeller
« Reply #8 on: March 31, 2008, 12:03:27 pm »
I am working it it, I have 11 sets I am currently cleaning up and bending.  They will be approx $45 plus shipping, mounting hardware included.
Jeff
'73 swb 2wd
73-87.com
Offline 81Cheyenne
« Reply #9 on: March 31, 2008, 02:48:56 pm »
those brackets look pretty good there Bigblock....Can you post some pics if them installed when you get a chance? I might be interested in a pair too.
Offline okuma
« Reply #10 on: March 31, 2008, 05:59:45 pm »
DO THIS BRACKETS SEAL UP NICELY AGAINST THE CAB?  or  Do they have gaps around the bracket and cab?
Offline bigblock73
  • Yeller
« Reply #11 on: March 31, 2008, 08:35:27 pm »
The top radius and inside of the bracket are tight to the cab.  The outside is pretty close, but the door opening is curved so there is a slight gap there.  The bottom is open.  I will get installed pics soon, I hope by the weekend.  I work long days, spend time with my wife and 5 month old after work...so time is limited.  I am only making these because I made myself a set...figured I'd help some others out.  I am not getting rich off these folks, nor do I intend to.
Jeff
'73 swb 2wd
73-87.com
Offline okuma
« Reply #12 on: April 01, 2008, 07:55:15 pm »
good enough response for me ! ;D
