Author Topic: rods  (Read 6870 times)
Offline mikewb
rods
« on: March 18, 2008, 07:02:50 pm »
when putting the vortec heads on my old block. which pushrods should i use. the ones that were there. or the ones that came on the vortec motor?
Offline HAULIN IT
Re: rods
« Reply #1 on: March 18, 2008, 08:39:53 pm »
Mike, The ones for the Vortec engine will be too short, due to you having flat tappet lifters in your engine. You need to check the pushrod length carefully any time you alter any part of the valvetrain or engine parts such as block deck hight,head gasket thickness, heads, ect. Depending on the "stack-up" of the varying parts & pieces neither one will most likely be correct. Right of of the top, what rocker arms you use plays a big part in it. It will be best to make or buy an adjustable length pushrod for checking, then purchase the ones that produce the correct pattern throughout the motion. Lorne
Offline d stroud
    • Our Cars
Re: rods
« Reply #2 on: March 19, 2008, 07:48:15 am »
I have set-up and used Vortec heads on 3 different engines including the one currently in my '85 GMC.  Each time, I used pushrods from the base engine (not the vortec push rods).  The geometry worked perfect each time.
Our Family Muscle Site
Yeah, Its got a Hemi...Just sucked one down the carb a few blocks back.
Offline mikewb
Re: rods
« Reply #3 on: March 19, 2008, 01:02:53 pm »
intsalled heads now my motor barely will crank over. tried to fire a couple times but now starter barely cranks and clicks
Re: rods
« Reply #4 on: March 19, 2008, 02:03:35 pm »
Is the battery dead? firing order right? Distributor in correctly?
Offline mikewb
Re: rods
« Reply #5 on: March 19, 2008, 03:49:09 pm »
yeah . idk . starter is strugglin to turn. and caught on fire.
Offline HAULIN IT
Re: rods
« Reply #6 on: March 19, 2008, 05:12:48 pm »
Mike, Are you sure the distributor is not in 180* out? That would be my guess from your description. Lorne
Re: rods
« Reply #7 on: March 19, 2008, 05:19:04 pm »
Your starter caught on fire? I would go over everything you did with a fine tooth comb
Offline mikewb
Re: rods
« Reply #8 on: March 19, 2008, 07:02:12 pm »
i got it runnin but once i did some of my rockers loosened back up? should i have to re tighten them?
Re: rods
« Reply #9 on: March 19, 2008, 07:09:43 pm »
how did you adjust them?
