Author Topic: Please tell me what these heads are?  (Read 11322 times)
Offline Robry 87
« on: March 20, 2008, 12:00:31 am »
I've got two new set of heads but are thay worth useing can anybody tell me the cc, and year?3998983 and 333882 it could be 338882.
Offline 1976Scottsdale
Re: Please tell me what these heads are?
« Reply #1 on: March 20, 2008, 11:19:59 am »
882's are open chamber 76cc crack proned smog heads.  They are okay for a bone stock, low HP engine.  DO NOT get them hot or they just crack.  A 160 thermostat and a 3 or 4 row radiator are your best friends. ;D
Offline Robry 87
« Reply #2 on: March 20, 2008, 01:12:18 pm »
Ok good so that set will work on a stock motor.BUT how about the other set the #'s on the them are side to side not up and down like all the other sets i've seen there sopost to be off of a 71 vett motor?but there is a 7# code on the other heads not 6 like all the others i've seen.I don't no where to look up #s at.
« Reply #3 on: March 20, 2008, 05:21:54 pm »
I don't recognize that#. Double check it
Offline Robry 87
« Reply #4 on: March 20, 2008, 11:42:36 pm »
I'll post a pic today so everybody to see them.
Offline Robry 87
« Reply #5 on: March 21, 2008, 07:48:53 pm »
Never mind guy's i cleaned them heads up and the set with the #'s3998983 is bad between cylinder's but sill would like to no the year and cc i've searched all over the inter net but no luck.
« Reply #6 on: March 22, 2008, 08:57:37 am »
make sure you're reading the # carefully and that it is the correct # sometimes 3 look like 8's etc. Not a very common casting # if it is correct.
Offline bigkountry
« Reply #7 on: March 22, 2008, 05:48:29 pm »
Heres a couple that it might be? Just a thought.
3998993 350 Goodwrench crate engine, Mexican made
3998993....72-73...307/350......75cc chambers
Heres a short discussion on a vette forum as well.
http://www.corvetteforums.com/m_25311/tm.htm
