Author Topic: Where does it go (temp sending unit wire)?  (Read 5444 times)
Offline bake315
« on: March 21, 2008, 09:22:39 pm »
The wire running from my temperature sending unit on my '73 C20 is in pretty rough shape and I want to replace it.  After it leaves the left side of the engine, and winds around back behind it, where does it end up?
Thanks, Dave
• '73 Cheyenne Super C20 454/400 http://forum.73-87chevytrucks.com/smforum/index.php?topic=7672.0
• ’79 Scottsdale K10 350/NP208/SM465 “Oscar” http://forum.73-87chevytrucks.com/smforum/index.php?topic=37885.0
Re: Where does it go (temp sending unit wire)?
« Reply #1 on: March 21, 2008, 11:28:51 pm »
at your gauge or warning lamp circuit.
Offline HAULIN IT
« Reply #2 on: March 21, 2008, 11:50:25 pm »
Dave, You can replace it from the engine over to the bulkhead plug (square plug below & left of the master cylinder) Either splice in a new section back by the firewall or better, remove the center bolt on the bulkhead plug, find the wire & carefully pick the tab holding the wire in the plastic. Replace with a new wire using the metal connector over. Lorne
Offline bake315
« Reply #3 on: March 22, 2008, 09:47:11 am »
Cool.  This really helps.  Thanks, Lorne!
