Author Topic: starting problems  (Read 5654 times)
Offline marcautodixon
starting problems
« on: March 24, 2008, 12:28:38 am »
hi everyone my name is marc and I have a 86 c10 longbed. I pulled the v-6 out of it and replaced it with a v-8 5.7 with vortec heads. I placed a lot of add ons like a Holley carb 650cfm , headman headers, dual exhaust, KnN filter, and Optima battery. It ran like a champ for a while until one day as I was driving to work it just stopped. I could get it started every now and then. when I say it stopped I mean no power at all. these are the things that I have changed out: starter, ignition switch, battery, key cylinder, fuses, buzzer. I thought I had a short in my system because I could start it some days and sometimes nothing at all. When I try to start it I get nothing, no electricity to the dash , no buzzer, no sound to the fuel pump, nothing. I am getting power to the starter but the starter doesn't turn and I made sure my body ground was clean. My engine ground is good too. I AM STUMPED. I need help. I thought it was the ignition switch but I replaced it and still nothing. ANYBODY HELP ME SAVE MY TRUCK
MARCAUTODIXON
Offline DnStClr
Re: starting problems
« Reply #1 on: March 24, 2008, 01:21:57 am »
Have you looked at the wire going from the battery to the starter to see if it might be rubbing on the header?
Don
87 Chevy Silverado
« Reply #2 on: March 24, 2008, 06:33:26 am »
Check your fusible links and like don said, the B+ cable to the starter solenoid.
Offline Swims350
    • Cars and trucks
« Reply #3 on: March 24, 2008, 10:52:34 am »
I had that problem in my monte carlo, ended up being starter solenoid bad, and neg wire from battery to fender corroded and in need of a clean and strip.
www.cardomain.com/id/benwa454
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
« Reply #4 on: March 24, 2008, 11:35:24 am »
Take a lesson from your's truly.......
This thread shows two pages of info you might find useful
My thread on burnt starter cable and fusible links
Re: starting problems solved
« Reply #5 on: April 17, 2008, 06:57:49 pm »
HEY I FOUND MY PROBLEM. SHORT IN THE WIRE THAT GOES TO A RELAY MOUNTED UNDER THE HOOD ON THE DRIVERS SIDE. SMALL SHORT IN ELECTRICAL SYSTEM. RUNS LIKE A CHAMP NOW. THANKS FOR ALL THE HELP. MY NEXT MISSION IS TO GET A GOOD TRANSMISSION AND A CAM. I WOULD LIKE A SUPERCHARGER TOO BUT MY POCKETS NEED TO BE A LITTLE MORE FULL. ANY SUGGESTIONS ON A CAM AND A GOOD TRANSMISSION TO MAKE MY 350 5.7 RUN ITS ASS OFF?
MARCAUTODIXON
Offline Bowtie Bomber
  • Rolling American Iron
« Reply #6 on: April 17, 2008, 07:19:24 pm »
HEY I FOUND MY PROBLEM. SHORT IN THE WIRE THAT GOES TO A RELAY MOUNTED UNDER THE HOOD ON THE DRIVERS SIDE. SMALL SHORT IN ELECTRICAL SYSTEM. RUNS LIKE A CHAMP NOW. THANKS FOR ALL THE HELP. MY NEXT MISSION IS TO GET A GOOD TRANSMISSION AND A CAM. I WOULD LIKE A SUPERCHARGER TOO BUT MY POCKETS NEED TO BE A LITTLE MORE FULL. ANY SUGGESTIONS ON A CAM AND A GOOD TRANSMISSION TO MAKE MY 350 5.7 RUN ITS butt OFF?
TH350 or 700R4 for a tranny. And personally I'd get this for a cam. http://store.summitracing.com/partdetail.asp?part=CRN%2D100132&autoview=sku
Also, is the cam shaft in your motor now a hydraulic or a roller?
« Last Edit: April 17, 2008, 07:21:02 pm by Bowtie Bomber »
My truck is my flying fortress, the road is my sky, and Toyota's are the enemy bunkers that need a busting.
