Interior & Equipment
Seats and Restraints
interior switch
Topic: interior switch (Read 33236 times)
hotrod24
interior switch
March 25, 2008, 12:38:18 pm »
here is my truck with the 73-76 belts but i want to switch to 78 belts i think thay are interchangeable
Last Edit: April 11, 2008, 04:20:23 pm by hotrod24
1978 pontiac grand prix...
hotrod24
seat differences?
March 25, 2008, 01:31:04 pm »
i have a 73-76 seat in my truck and i want to switch to 78 seat belts so would i have to find another seat to make everything match
seat differences?
March 25, 2008, 01:55:00 pm »
Match how? The seats are all the same.
hotrod24
Re: seat differences?
March 25, 2008, 02:08:28 pm »
so chris are you saying all i have to do is get 78 seat belts and it will be ok
the_legend_1981
March 25, 2008, 02:21:30 pm »
yeah thats what he's saying.
hotrod24
March 25, 2008, 02:31:15 pm »
how about the plastic cover behind the seat belt housing i know them are different
March 25, 2008, 02:35:09 pm »
Your shoulder harness seat belt will already have the plastic cover on it. If you want to color match you'll either have to find the same color or dye/paint them.
⌠ŻŻŻŻŻ' [☼===☼]
hotrod24
March 25, 2008, 03:22:39 pm »
ok that is good would i have to switch the cover on the seat it sticks out i dont think that the seat belt would fit
Last Edit: March 25, 2008, 07:29:40 pm by hotrod24
hotrod24
March 26, 2008, 01:54:09 pm »
is there a way to die your cloth seat belts mine are blue and i want them black or gray
Last Edit: March 26, 2008, 07:25:30 pm by hotrod24
March 26, 2008, 08:51:06 pm »
It'd be easier to dye them black. You can either use a fabric dye or use fabric paint. Just test it before you wear nice clothes and put it on. =P
⌠ŻŻŻŻŻ' [☼===☼]
hotrod24
March 26, 2008, 09:02:00 pm »
ok cool
Swims350
March 26, 2008, 09:29:53 pm »
duplicolor or sem, duplicolor is cheaper and works fine.
I did the light grey seats in my monte carlo with duplicolor black and they don't rub off on you. I'd worry more about vinyl seats coming off on you or coming off period then cloth, it soaks it up. I say 2 cans maybe 3 and you're set.
As for your seat belt things justy use some prep wipes, or wax grease remover then spray them, you can use krylon on the hard plastic stuff, and you can even do the belts themselves I did.
www.cardomain.com/id/benwa454
bigkountry
March 27, 2008, 11:37:16 am »
You can also use RIT dye, found at any walmart store where the laundry detergent is.
Get a big pan (stew pot, etc.), some dye, water and drop them in per the instructions. The black is real dark too, not expensive at all either. This is for the belts, I have dyed some plastic with it but had mixed outcomes, hard to match up the colors if you do one piece at a time.
Swims350
March 27, 2008, 01:00:22 pm »
well with the duplicolor and other spray dyes it's no problem to match it up it'll match right out of any can.
I had 14 cans and done each piece by itself and it all matches perfectly.
I bought several cans at a time from different stores, at different times.
bigkountry
March 28, 2008, 04:49:11 pm »
I have also used the duplicolor for plastic with great results.
interior switch
