Author Topic: GM TH375  (Read 7602 times)
Offline mike in mo
GM TH375
« on: March 27, 2008, 02:28:16 pm »
OK a guy give me this tranny with no converter i know it worked good as it was in a truck he drove. don't know where the converter went but i need to find one so i went looking in summit and it said 350/375 and 400 are all the same so i tryed to put a 350 converter in it and it don't fit whats the deal. i know the 375 is more like the 400 so do i need a 400 converter or is it 375 only? its got a wire running out the side of it so do i need a lock up converter?
Re: GM TH375
« Reply #1 on: March 27, 2008, 02:49:05 pm »
You need a converter for a TH400/TH375
Offline Leevon
  • "Common Sense Ain't So Common"
Re: GM TH375
« Reply #2 on: March 27, 2008, 03:35:51 pm »
The single wire is for kickdown, on my '87 it's computer controlled.  I just removed one of these trannys last weekend you're welcome to the converter if you're close to NW Arkansas.  I don't know what you're swapping from but the length from bellhouse to tailshaft is 33 7/8...you may have to shorten the d-shaft?
1950 3100
1971 Cheyenne
1987 Silverado
2018 Silverado
Offline mike in mo
Re: GM TH375
« Reply #3 on: March 27, 2008, 09:17:00 pm »
cool i got a 400 converter around here someplace got to find it in my mess the 375 is going in place of the 400 i smoked in my 4 door. ill have to keep burning autos till i find time to make it 4 speed
Offline mike in mo
Re: GM TH375
« Reply #4 on: March 29, 2008, 09:50:04 am »
if the 375 is 33 inchs how long is the 400 i was told the 375 is a 400 with a slip yoke so ?
Re: GM TH375
« Reply #5 on: March 29, 2008, 11:18:10 am »
I was under the impression that the TH 375 was all TH 400 with the exception of a smaller TH 350 rear output shaft/spline.
