Author Topic: 79 sierra hombre Need help with 350  (Read 5992 times)
Offline 79 sierra hombre
« on: March 30, 2008, 12:28:51 pm »
i to want to replace card on my 1979 v8 350 sierra grande ,  but dont know what do to,  i dont want 4 barrel card, do to gas,  what do the great minds here sugest?
exhaust smells a lil rich,   like gas,  what should i do?
« Reply #1 on: March 30, 2008, 05:19:52 pm »
What's card? Do you mean carburetor? What do you have on it now? What you should do is tune it up, set the timing and adjust the carburetor and go from there.
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
Re: 79 sierra hombre Need help with 350
« Reply #2 on: March 30, 2008, 08:46:35 pm »
I think he means carB.  If it has a 4bl on it now, I'd keep it rather than replacing the intak manifold from a 4 bl to a 2 bl intake.  I 4bl carb can get quite good mileage if you don't open up the 4 barrels, and just drive it with the two barrel, in other words, don't stomp the gas.
As vile said, adjust the carb if it is a little rich.  Adjust the timing as well.
« Reply #3 on: March 30, 2008, 08:52:35 pm »
rebuild  the 4 barrel, tune-up but no 2 barrel. I have switched to a 2 barrel many years ago thinking it would help gas mileage, and made it worse. Gas mileage is controlled by your foot on the little skinny pedal.
« Reply #4 on: March 30, 2008, 09:51:51 pm »
I had done the same thing about 25 years ago on a 72 C-10 I had.  I actually played with the jets and got better.  The exhaust pipes burned clean with a light grey color and it passed emissions standards for the day.  Just a Rochester 2 bbl
