Author Topic: Overdrive  (Read 23518 times)
Re: Overdrive
« Reply #15 on: April 02, 2008, 06:23:36 pm »
Just to verify it's not a linkage issue, if you shift up manually one more does it go into Neutral?
Offline 76_Scottsdale
  • I'd rather push my Chevy than drive a Ford
Re: Overdrive
« Reply #16 on: April 02, 2008, 06:42:18 pm »
Yup. I talked to a tech at Bowtie today. He said next thing to do is drop the pan and verify that the 4th gear valve isn't stuck and make sure it is able to move back and forth. That's getting done tomorrow. If there's something wrong with the valve assembly, they'll ship me out a new valve body.
1976 Scottsdale K20
350 C.I.D.
700R4
NP205
2 1/2" Lift
305/70/R16 BFG MT
True Dual 3" Flowmaster 40 Series Exhaust
Offline Hank Hill
Re: Overdrive
« Reply #17 on: April 04, 2008, 08:23:53 am »
When I put a rebuilt th350 into my truck the shift points were different at first. Example the shift points were all lower. It was like going from 308 rear end gears to 410s. Example it was shifting into 3rd gear at speeds where it should normally only be going into 2nd gear. I just drove mine and after 100 miles it fixed itself. Have no idea what was going on.
Re: Overdrive
« Reply #18 on: April 06, 2008, 02:29:39 pm »
Can anyone provide a picture showing the 4th gear valve in the vavle body so I know which one to un-stick when I pull the pan?
1976 Scottsdale K20
350 C.I.D.
700R4
NP205
2 1/2" Lift
305/70/R16 BFG MT
Re: Overdrive
« Reply #19 on: April 06, 2008, 02:54:07 pm »
what year is your trans?
Re: Overdrive
« Reply #20 on: April 06, 2008, 08:44:36 pm »
I honestly have no idea because I bought it from Bowtie but it does have TCC lock up if that matters. So once the pan is off I should be able to get a small dental pick up in there and pull out that 3/4 shift valve right?
1976 Scottsdale K20
350 C.I.D.
700R4
NP205
2 1/2" Lift
305/70/R16 BFG MT
Re: Overdrive
« Reply #21 on: April 09, 2008, 01:24:41 am »
anyone?
1976 Scottsdale K20
350 C.I.D.
700R4
NP205
2 1/2" Lift
305/70/R16 BFG MT
Re: Overdrive
« Reply #22 on: April 09, 2008, 10:34:59 am »
no, you will not have the shift solenoids like pictured above. You'll need to drop the valve body. Take a pair of dykes or needle nose pliers and slide the roll pin up and you can remove the valve. Are you capable of taking apart the valve body and will this void your warranty?
Re: Overdrive
« Reply #23 on: April 09, 2008, 04:01:55 pm »
The way the guy at Bowtie explained it to me, he said I should be able get to the valve with out dropping the valvebody, so maybe I have the other kind of tranny?
1976 Scottsdale K20
350 C.I.D.
700R4
NP205
2 1/2" Lift
305/70/R16 BFG MT
Re: Overdrive
« Reply #24 on: April 09, 2008, 04:04:09 pm »
The other kind of tranny? What does he want you to do? Just try and move the valve with a pick tool? you might be able to move it a tad without dropping it.
Re: Overdrive
« Reply #25 on: April 09, 2008, 09:15:38 pm »
Yes, he wants me to move the valve a little with a pick to try and unstick it. He said once it's unstuck it should be fine, and if not then I'll drop the valve body and they'll send a new one.
1976 Scottsdale K20
350 C.I.D.
700R4
NP205
2 1/2" Lift
305/70/R16 BFG MT
Re: Overdrive
« Reply #26 on: April 09, 2008, 09:17:11 pm »
How much did you pay for this trans if you don't mind me asking?
I just can't believe they don't dyno test their transmissions.
Re: Overdrive
« Reply #27 on: April 09, 2008, 09:29:41 pm »
The tranny was $1295 bones. I believe the tranny was tested and sat on a shelf until I bought it which really erks me. The one thing I've ever bought from them acts up. Needless to say I'm not buying anything from them again.
If I get the pan off tonight Vile would you be able to explain where the 4th gear valve is at when you're looking up at the valve body?
Thanks for your help.
1976 Scottsdale K20
350 C.I.D.
700R4
NP205
2 1/2" Lift
305/70/R16 BFG MT
Re: Overdrive
« Reply #28 on: April 09, 2008, 09:34:18 pm »
Let me log into ATRA and see if I can find you a diagram
Here ya go
« Last Edit: April 09, 2008, 09:41:12 pm by VileZambonie »
Re: Overdrive
« Reply #29 on: April 09, 2008, 09:40:37 pm »
thanks i'll check back in a few i'm gonna go drop the pan.
Thanks Vile
« Last Edit: April 09, 2008, 11:36:16 pm by 76_Scottsdale »
1976 Scottsdale K20
350 C.I.D.
700R4
NP205
2 1/2" Lift
305/70/R16 BFG MT
