Performance
Performance Distributors
Topic: Performance Distributors (Read 8120 times)
SUX2BU99
March 31, 2008, 11:56:00 am »
What's a good drop-in HEI to use? I've been seeing the ads for the D.U.I. distributors and they intrigue me because of the custom curve they will build into the unit for your particular setup. Of course there are the usual MSD, Mallory, Accell HEI's but they offer several and I'm not looking for ultra-fancy (and pricey) setups, but would like a decent $150-199 HEI that will make my new cam and head swap do all that it can. My 350 has a stock HEI now that I've replaced the cap and coil with an MSD not all that long ago and it has nice Aurora performance wires on it already. Thanks.
Re: Performance Distributors
March 31, 2008, 12:02:05 pm »
Summit has their own brand line that I've heard good things about.
⌠ŻŻŻŻŻ' [☼===☼]
SUX2BU99
March 31, 2008, 02:11:23 pm »
Yeah I was checking out what they have and $90 for a new 'blueprinted' HEI is a pretty darn good value. The D.U.I. one is like $270 I have come to find out. Custom curve is cool, but that's a little out of my price range. Lots of Summit's house brand parts are really good values. I am cautious though if the quality is there.
March 31, 2008, 02:25:19 pm »
One thing I can vouch for is Summit's cams. Edelbrock told me on the phone they do NOT make their own cams so you are just paying for the name when you buy brands like Edelbrock. So far I have had 2 Edelbrock cams fail and one be 8° retarded yet I've never ever had a Summit cam fail me and they're dirt cheap. Summit is also really good with warrantying their own products so I wouldn't hesitate. One thing you should never skimp out on though is the ignition system. I always use top quality everything ignition.
⌠ŻŻŻŻŻ' [☼===☼]
SUX2BU99
March 31, 2008, 03:53:43 pm »
Good info Vile. I'm thinking about splurging for an MSD or a Mallory. I'm thinking this:
http://store.summitracing.com/partdetail.asp?autofilter=1&part=MSD%2D8362&N=700+4294925143+4294881256+4294908395+4294881255+4294908216+4294881252+4294840140+115&autoview=sku
Or this:
http://store.summitracing.com/partdetail.asp?autofilter=1&part=MAA%2D8548201C&N=700+4294925143+4294881256+4294908395+4294881255+4294908216+4294881252+4294840140+115&autoview=sku
The Mallory is a little prettier with that flat top-hat and it's a bit cheaper too.
Last Edit: March 31, 2008, 03:58:10 pm by SUX2BU99
March 31, 2008, 04:00:30 pm »
How bout this one
http://store.summitracing.com/partdetail.asp?autofilter=1&part=SUM%2DCSUM2700&N=700+%2D203994+115&autoview=sku
Or this one if you don't want vacuum advance
http://store.summitracing.com/partdetail.asp?autofilter=1&part=SUM%2DCSUM2701&N=700+%2D203994+115&autoview=sku
⌠ŻŻŻŻŻ' [☼===☼]
SUX2BU99
March 31, 2008, 05:35:36 pm »
I never really thought about getting an outboard box like a 6AL or the like. Didn't really figure I'd need it and would just rely on the regular HEI with a quality coil and distributor. Speaking of MSD boxes, I've heard of quite a few that have gone bad, leaving drivers to unplug it to get the motor to fire.
March 31, 2008, 06:12:56 pm »
I've had the same 6AL on my 74 GMC for 10 years now. I've always covered mine when I wash the engine compartment, It's away from heat and vibration and works great still.
Anyone not running a factory HEI will vouch for it being worth every single penny. You WILL notice a major difference.
⌠ŻŻŻŻŻ' [☼===☼]
Blue 82
March 31, 2008, 06:59:45 pm »
I needed a tune up for my 82
By the time I priced a good cap and rotor
for a few bucks more,
I just bought a new HEI on Ebay
http://cgi.ebay.com/ebaymotors/SBC-BBC-CHEVY-HEI-DISTRIBUTOR-65K-COIL-RED-8909-R_W0QQitemZ250230863062QQcmdZViewItem?hash=item250230863062
this one has the adjustable vacuum rate advance
A 65K coil and is 100% new
The only thing I needed which I pulled from my old distributor,
was the advance springs and the vacuum advance limiter plate
(both made by crane cams)
The crane cams kit runs about $20 and is well worth it for any HEI
http://www.cranecams.com/pdf/254g.pdf
I installed this dist in my truck about 3 weeks ago
Out of the box the mechanical springs were way too heavy for my application
it also provided about 15 degrees of vacuum advance (5 too much for me)
they even provided a new gasket
It runs better than my old HEI
that had the ZZ4 module, Accel coil and adjustable vacuum rate cannister/kit from crane.
just my $.02
(the crane kit comes with the adjustable vacuum cannister/ springs/ and vacuum limiter plate for approx $20. the limiter plate alone is like $5)
O
Last Edit: March 31, 2008, 07:02:57 pm by Blue 82
bigkountry
April 01, 2008, 11:23:10 am »
I run Accel HEI with supercoil on mine and haven't had a problem yet.
SUX2BU99
April 01, 2008, 12:00:58 pm »
I think in the interest of my budget, I'll get the Mallory HEI and forego the Summitt set with the outboard box (for now). It would be an easy sell in the future if I decide to upgrade to something like that Summitt kit. I have to keep some money avaiable for a new Weiand alum. water pump.
April 01, 2008, 01:17:22 pm »
I'd put my $ into the ignition system over the aluminum waterpump. The Mallory is good though ...Good luck with it!
⌠ŻŻŻŻŻ' [☼===☼]
SUX2BU99
April 01, 2008, 01:43:58 pm »
I hear ya, and it probably makes more sense to do that. But, it's a lot easier for me to swap out a distributor than it is a water pump!
Thanks for everybodies input.
75stepside454
April 01, 2008, 05:00:09 pm »
Ive had a D.U.I. H.E.I in my 454 for almost 5 years. best Dizzy Ive ever had.
chevy87truck
September 15, 2008, 11:48:13 pm »
i had bought a proform complete distributor from jegs, it crapped out so i got my money back and bought a performance distributors complete. it runs awesome, and looks good too.
87' swb 350 tbi-700r-4. holley tbi, full exhaust, full ignition, 3.42 gears, lowered, 2600 stall.
15.5 @ 87
Performance
