Interior & Equipment
Instrumentation
2" Tachometer
Topic: 2" Tachometer (Read 12376 times)
choptop
Extended cab fanatic
2" Tachometer
March 31, 2008, 07:44:43 pm »
I am working with a guy to build a 2" Tach that bolts in anywhere a standard oil psi or water temp gauge fits. I will be using one in my choptop's custom dash, but primarily in the Industrial engine controls I build. My question is, is anyone intersted in a 2" tach? Trying to consider if it will be feasable for automotive use. I am working with him to design it due to limited space in some control panels. Let me know what you think.
Re: 2" Tachometer
March 31, 2008, 07:47:14 pm »
Just use one for like a harley...
http://www.jimshd.com/eshopprod_cat_3837-36802_product_468031.2_Tachometer_Gauge.htm
http://www.iboats.com/Tachometer_Electric/dm/dz.4493--view_id.191145
http://svx-motorsport-accessories.stores.yahoo.net/autometertach.html
http://search.ebay.com/search/search.dll?from=R40&_trksid=m37&satitle=2%22+tach
Last Edit: March 31, 2008, 07:50:35 pm by VileZambonie
choptop
Re: 2" Tachometer
March 31, 2008, 07:52:10 pm »
Hadn't seen that one, but it won't work for the application I am working on because the imput pulses will be quite different on a twin than on a 6 or 8, let alone the magnetic pickup signal on most industrial engines. Don't know if the Harley one is adjustable.
red4wd
Re: 2" Tachometer
March 31, 2008, 07:57:27 pm »
Choptop you don't by chance do propane irrigation engines do you?
choptop
Re: 2" Tachometer
March 31, 2008, 07:59:02 pm »
I did alot of them in the past,but now mostly industrial deisel engines and generators.
Redneckchevy
Re: 2" Tachometer
March 31, 2008, 08:08:18 pm »
UM...summitautoracing sells one....
choptop
Re: 2" Tachometer
March 31, 2008, 08:09:57 pm »
I found the one with the digital display and shift light. Look ok, but the lights make it look dumb. I am wanting it with a needle, and not so cluttered looking.I am getting these built for industrial engines, just wanted to see if anyone would want it for automotive. I am hoping to beat the $150 range though. Seems a little steep.
Last Edit: March 31, 2008, 08:20:09 pm by choptop
zieg85
Re: 2" Tachometer
March 31, 2008, 08:57:35 pm »
There is a 2 inch that fits the factory clock hole in a Chevelle with the standard sweep speedometer. If I can find the link, I will send it along.
Stewart G Griffin
Re: 2" Tachometer
April 01, 2008, 09:11:00 am »
i think the 2" tach does hold merit, especially for people like me ,who, aren't racing, aren't really into high performance and just want to know how fast the engine is turning at any given road speed. (So this means we really don't want a giant tach to clutter up space etc.)
Sort of like this one, except smaller?
http://www.jegs.com/i/Auto%20Meter/105/2306/10002/-1
However, i think if you can come up with a way to mount a gauge without drilling and/or the steering column thing, you'll get all the marbles. For example, possibly mount to the rear view mirror or something. Or produce a pillar for the 73-87 trucks; Inexplicably, no-one sells one.
That being stated, i feel that the 2" tach intended to go in where a std oil or temp gauge would go
might
sell if it's high-quality and at the right price.
zieg85
Re: 2" Tachometer
April 01, 2008, 09:19:48 am »
I had it stored as a bookmark for future reference but the webpage is gone. If I can come up with it again, I will post it. Here is what it looked like.
Instrumentation
2" Tachometer
