Author Topic: Oil leaks, oil pan, valve covers (big block)  (Read 6860 times)
Offline xtremjeepn
« on: April 02, 2008, 11:00:15 am »
Aside from just replacing old gaskets on the pan and valve covers (1974 454)  are there any newer better solutions for stopping oil leaks. (like valve covers with a newer design for old heads etc).
Looks is not may main concern but keeping ALL the oil off my parking spots is.
Cole
Restomod Crew Cab Short box on 37"s
Re: Oil leaks, oil pan, valve covers (big block)
« Reply #1 on: April 02, 2008, 07:06:24 pm »
sure....only use RTV when necessary and use this kind
Always install all bolts before tightening any and torque to specs with a torque wrench.
For the intake manifold, ditch the end seals and use a center punch to make a series of impressions along the ridge. Use RTV instead of the end seals.
If you have a 2 piece rear main seal, offset the seal so that the ends don't line up with the bearing cap.
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
« Reply #2 on: April 02, 2008, 08:14:17 pm »
Get those kind of spreaders that spread the pressure of the bolt....like on my 383 stroker....
They are called spreader bars....
http://store.summitracing.com/egnsearch.asp?N=700+115+309753&D=309753
Make sure your valve covers are not warped....double up your gaskets could be a possiblity.
