Performance
eletric supercharger??
Topic: eletric supercharger?? (Read 11478 times)
stevens
April 08, 2008, 08:48:37 pm »
any body ever heard any thing about them? I found them on ebay and was wondering if there worth or crap or not?
http://cgi.ebay.com/ebaymotors/Chevy-Chevrolet-Supercharger-Turbo-Cobalt-Cavalier-z24_W0QQitemZ370040078877QQcmdZViewItem?hash=item370040078877
eventhorizon66
Re: eletric supercharger??
April 08, 2008, 08:53:30 pm »
garbage
'85 C10 SWB 350
700R4
TKO600
FlatBroke
April 08, 2008, 09:01:10 pm »
I read up on those a few years ago, seems like I remember they offer about 1psi boost (depending on what motor they are installed on) Just didn't seem like "Money well spent" to me.
It's not the tires screaming, It's the asphalt
http://forum.73-87chevytrucks.com/smforum/index.php?topic=7217.0
April 08, 2008, 09:29:42 pm »
It looks like a draft inducer for a furnace.... Go for it and let us know how you make out. lol
⌠ŻŻŻŻŻ' [☼===☼]
BeaverBanker
April 08, 2008, 10:02:43 pm »
i might put that on my lawn mower.. but thats it... if you really wanna try something cool.. use a leaf blower
1985 Chev K20 350/465/205, 44/14FF, 9" lift with 37's, Roll Bar, Winch & 70's Front Clip
1999 Silverado 1500 - Daily driver
April 08, 2008, 10:03:49 pm »
Seriously, don't waste your money. That guy is a turkey
⌠ŻŻŻŻŻ' [☼===☼]
stevens
April 08, 2008, 11:00:27 pm »
haha thats what i thought, a leaf blower would be funny!
Are there any afordable supercharger kits for are trucks? I wana see pic
April 08, 2008, 11:24:27 pm »
not unless you can afford to spend $5k
⌠ŻŻŻŻŻ' [☼===☼]
April 09, 2008, 10:50:39 am »
Describe affordable... If it is under $3000, you are looking at used..
eventhorizon66
April 09, 2008, 11:07:00 am »
So I guess you guys feel that the Weiand's little
142
is worthless as well? It can be had for about $1850 satin finish new. What about a Magnuson eaton-style
supercharger
for about $3000 new. Or where you referring to centrifugal chargers only? Not trying to be snotty, I'm really curious.
Last Edit: April 09, 2008, 11:10:44 am by eventhorizon66
'85 C10 SWB 350
700R4
TKO600
April 09, 2008, 01:23:38 pm »
no, don't think it is worthless, but you have to have carbs built for a supercharger, not to mention all of those "gotcha's" that you don't realize until you sunk $2000 in a blower. My twin brother did this on his Camaro. Ended up with more than $3000 in an "only $1850" blower.
April 09, 2008, 04:21:45 pm »
Yeah it's not the blower by it'self....what kind of drive system do you need? What Compression ratio will you have? Do you have a steel crank and forged rods? Forged pistons? What's your camshaft profile? Fuel system, exhaust system.... If you simply just bolt on a supercharger and expect fantastic results it's not going to happen.... most likely you will end up with an engine going to an early grave with a pretty supercharger on it. If you want an exotic set up it realistically needs to be on a capable structure and it's not going to be "cheap"
⌠ŻŻŻŻŻ' [☼===☼]
eventhorizon66
April 09, 2008, 05:43:00 pm »
Oh, I see what you mean, then.
'85 C10 SWB 350
700R4
TKO600
stevens
April 09, 2008, 11:09:40 pm »
will 6-8 psi really put that much pressure on the motor? jw
78 big ten 355
April 10, 2008, 06:39:56 am »
You are not just increasing 6-8 psi, that is boost pressure and actulally low for the potential of a supercharger. The added air forced into the cylinder means more oxygen. This creates extremely high cylinder pressures during combustion.... Without extensive mods you'll be twizzlering connecting rods, spinning the nose right off of the crank, etc. Without controlled spark timing it would pop on the 1st run. So like said superchargers aren't bolt on by themselves mods. They require much more additional components and tuning which = $$
If you were going after cheap thrills N2O is the way to go.
⌠ŻŻŻŻŻ' [☼===☼]
Performance
