Author Topic: No rear brakes.  (Read 5540 times)
Offline cky686
No rear brakes.
« on: April 09, 2008, 11:18:01 pm »
ok so I have no rear brakes. the rears are drums. iv got new shoes and drums. they are adjusted correctly. and they have been bled. when i press the pedal there is no pressure until the pedal is about 2 inches from the floor then there's a little pressure. im starting to think it might be my master cylinder but im not quite sure.
thanks for your replys.
Offline Fordeatinz71
  • 78k miles and counting
Re: No rear brakes.
« Reply #1 on: April 09, 2008, 11:35:31 pm »
sounds like you have either air in the system or a bad M/C.  check your lines to the rear WELL...all the way down the frame.  make sure you don't have a leak or a crimped spot.  you might not be getting enough fluid to the rear to do the deed...
Re: No rear brakes.
« Reply #2 on: April 10, 2008, 06:30:37 am »
If everything is as you say, replace the M/C. Make sure you bench bleed it first!
