Engine/Drivetrain
Crank Casting number doesn't exist?? Any Help??
Topic: Crank Casting number doesn't exist?? Any Help?? (Read 19369 times)
85MudMonster
April 10, 2008, 12:02:04 am »
Okay, I've spent the last like 3 hours searching every possible combination of numbers and words to find the crank casting number I have, the closest number to what I have is a 14088526 which is a cast iron 86-up one peice rear seal crank, which from what I can tell just by looking at it is what I have, but my casting number is 14088528, and no I'm not reading it wrong. I've came across one site that mentioned that it might be a cast steel crank, can anyone help me out with this?
Thank you,
Dan
Dan
85 Chevy K10 - 408 BBC from a 71 Chevelle SS, TH350, NP208, 33" Mastercraft Courser M/T
Re: Crank Casting number doesn't exist?? Any Help??
April 10, 2008, 06:25:24 am »
Are you sure it isn't 14088523
85MudMonster
April 10, 2008, 11:27:46 am »
I don't think so, I looked it over real good again just to make sure of it, It is definately 14088528, but since I've seen a few other people on the net asking about this, why doesn't anyone have any info on it, just seems weird.
Dan
April 10, 2008, 12:43:47 pm »
would you mind taking a pic of the casting # for us?
85MudMonster
April 10, 2008, 03:42:34 pm »
here are a few, their the best I could get with the lighting and what not:
Dan
Blue 82
April 10, 2008, 08:21:57 pm »
I just built a 2 bolt main 350
It's still on the stand, oil pan side up
I too have the same crank casting number
1408852(?)
Even in the photos you posted the last number looks like an "8"
Looking at mine it hard to tell if the last numbers is an 8 or a 6.
but if you compare the two 8's in the middle,
you can tell they are different than the last number
the 8's in the middle have a small circle on top
and a big circle on the bottom of the 8
The last number looks as if both circles (?) are the same size, leading me to believe this is a "6", not an 8.
it's a nodular iron crank
http://paceperformance.com/index.asp?PageAction=VIEWPROD&ProdID=22893
the crank has additional numbers and markings on it
I can post the ones I have
but it will have to be tomorrow....
Last Edit: April 10, 2008, 08:43:13 pm by Blue 82
85MudMonster
April 10, 2008, 08:37:16 pm »
yes I can definately tell it is a cast crank from the thin parting line, but I'm still certain the last number is an "8" and not a "6" but I'm thinking of changing out the crank anyway...
Dan
April 10, 2008, 08:42:22 pm »
Hard to tell by your pix but I looked it up in a casting ID book I have and it says 350 cast crank one piece rear main seal
Blue 82
April 10, 2008, 08:49:11 pm »
Mine has a circle with a * in the middle with the letters CFD after it
Blue 82
April 10, 2008, 08:49:56 pm »
it's a nodular iron crank?
April 10, 2008, 08:51:52 pm »
Blue 82 I was referring to 85mudMonsters casting #
85MudMonster
April 10, 2008, 10:07:49 pm »
vile what book is it that you have and it actually had the 528 in it? was that all it said 350 1 piece seal and cast crank?
Dan
bigkountry
Reply #12 on:
April 11, 2008, 08:13:40 pm »
Could it just be a fault in the mold, there is no indention on the left side of the last number like the other 8's in the sequence?
hotrod24
Reply #13 on:
April 11, 2008, 08:17:50 pm »
i think this might help you
http://www.mortec.com/
1978 pontiac grand prix...
85MudMonster
Reply #14 on:
April 18, 2008, 10:20:57 am »
I don't know but I want a nodular or forged crank so this on is gonna go away since I can't figure out what it is....
Dan
Engine/Drivetrain
