Author Topic: new to all this, lowering  (Read 22150 times)
Offline sgoody43
« on: April 10, 2008, 06:47:13 pm »
I just wanted to ask what could I expect if I take off 1 1/2 coils off my 1/2 ton 87.  I have no money but  I want to lower my truck the old style, cutting the front coils and taking some leaves off.  so my question is.  Is 3 inches safe to lower by taking off coils. and in the back 4 of 5 taking leaves off..  or what do some of you guys sugest.  I just bought this truck so I have no budget , the truck is the budget.
Offline dueprocess
  • My 8yr old's tonka toy!
Re: new to all this, lowering
« Reply #1 on: April 10, 2008, 07:07:25 pm »
You will probly get a more formal reply from some of these guys but, i have had lowered trucks for a while and have a ton of friends with them. For the front coils, you will have to measure very precise to make sure they stay even and will privide a very bouncy ride(yet i understand the low budget)!  For out in the back, i would not recomend taking all leafs but one out. For me no more than 2 leafs..... Shackles are really cheap to catch 2inches safely.....
1978 Chevy K10 / 454bbc / Dana 44 with chromoly axles / 6in susp & 3in BL / 38.50x15 Boggers(rims 15x14)!
Offline sgoody43
« Reply #2 on: April 10, 2008, 08:31:31 pm »
forgot to mention I have 6 leaves on my 87 .  I like the idea of buying a 2 inch shackle and taking a leave or two off and taking a coil and a half off my front coil.  I just want to know how much coils do I take off for 2 inches, one coil or 1 1/2.  that is my main question
« Reply #3 on: April 10, 2008, 09:01:38 pm »
Don't go more than 1.5 coils! As far as the rear goes shackles are probably your best bet since you won't be going too low.
Offline FlatBroke
« Reply #4 on: April 10, 2008, 09:24:08 pm »
I agree with VileZambonie,
1 1/2 rounds is the most to cut up front..
I also know a little something about a tight budget.....
Keep asking questions around here, someone will give you good sound advice.
It's not the tires screaming, It's the asphalt
http://forum.73-87chevytrucks.com/smforum/index.php?topic=7217.0
« Reply #5 on: April 10, 2008, 10:47:20 pm »
You really don't want to lower one 3" with just coils and I third the opinion of not cutting more than 1.5 off..
Offline sgoody43
« Reply #6 on: April 11, 2008, 12:53:22 am »
thanks for the advise guys I will definatly not go past the 1 1/2 coils.  After reading on these forum I went to check my leaves and they are 56 inch across and there are 6 leaves so with that in mind what do you guys sugest for the rear.  I just ordered a 2 inch shackle from ebay for $43 (on a budget but still want to keep the truck capabilities so removeing 3 leaves was out of the question.)  Do you guys think the bottom 2 leavess  and a 2 inch shackle will match the 1 1/2 coil choppng out in the front.  buy the way I am getting more and more into this truck.  At first I just wanted a truck and I scored on my 87 350 fuel injected 1/2 ton shortbed fleetside , but now I want to make it look better, but all I have to barter are parts that I have acumulated. Thanks for the advise guy and belive me more questions will come.
« Reply #7 on: April 11, 2008, 11:40:57 am »
If you are doing this on a budget, are you having to drive the truck?  Reason I ask is if you can, I would lower the rear and then cut the front accordingly.
When I said I wouldn't cut more than 1.5 off, I meant at the max, so I would measure the truck first then take the spring and mark it at that point, cut both springs 1/2 coil, install it and DRIVE it, then see how it sits.  Make a note of the amount of drop and then cut 1/4 coil at a time.  This way you can fine tune the drop and not get too much.  Remember, if you cut it off too much, you are out of luck.  If you have a spare set of springs, you will be fine...
Offline sgoody43
« Reply #8 on: April 15, 2008, 06:36:15 pm »
what if I use spring compressos because my friend said he would give me a set, do you guys think they will work
« Reply #9 on: April 15, 2008, 11:28:49 pm »
No.  The only thing a spring compressor is good for is removing springs...
Offline dueprocess
« Reply #10 on: April 17, 2008, 06:50:42 pm »
Using the spring compressor as a lowering method to drive around on? I would think that would be dangerous and a accident waiting to happen! Just my .02cents!!!!!
Offline nativetexan
« Reply #11 on: April 18, 2008, 10:18:43 am »
I can surely understand a budget project. My 87 is a long way off from being where I want it. And my low low budget is keeping that progress at an almost standstill. But, I would say, scrape a $150 and get a pair of drop spindles for the front. That way it won't take away from the front suspension at all. You can deal with it for a while but the bouncieness will get to you sooner or later. I plan on getting some spindles for my 87 and I feel like it will be a good investment.
Offline sgoody43
« Reply #12 on: April 22, 2008, 11:18:27 pm »
sorry for the bumd sugestion but you guys baled me out before I made the mustake of trying spring compressors, but some one at work told me that thats what they used.  I now know for sure that I am going to cut one coil off the front and put a 2 inch shackle  with only four leaves.  How much do you guys think that will lower my truck?
I will save up later for the real 2 inch springs
Offline ccz145a
« Reply #13 on: April 23, 2008, 07:55:44 am »
Quote
Please follow this advise, it will save you time/money in the long run.
Offline sgoody43
« Reply #14 on: April 28, 2008, 07:19:01 pm »
ok guy I dit the shackles and I got as advertised 2 inches.  So that put me at 32 inches from fender to ground.  Then I went ahead and removed two leaves of leaving me with 4 leaves(from top to bottopm leave 1,2,3,5
took out leave 4 and 6.  I got another 1 and a 1/2.  Now I am at 30.5.  Front is 31.5.  One coil is 2 inches right just want to make sure.  I do like a little rake so if the front is an inch lower I will be happy, even also but  air bag look is a definate no no. >:(
