Author Topic: rear end question  (Read 3750 times)
Offline BoobZ
rear end question
« on: April 10, 2008, 07:59:38 pm »
ok so ive been doing the ole redneck rear gear check and i cant get it right..
since its an open diff. i only jacked ONE wheel off the ground to check this..
i can spin the Driveshaft 1 full rotation and i only get .75 turns out of the wheel.. 3/4s turns out of the tire..
I can spin the wheel 1 full rotation, and get about 1 and 1/3 rotation..
my question is, how come everywhere i look, i see people saying "you should be able to spin the driveshaft 2.73ish rotations before the tire completes a revolution"?
do i multiply the single wheel rotation trial by two making it 2 and 2/3 rotations? making it 2.73ish?
truck is an 86 2wd.. the code says it has a 2.73s in it..
Re: rear end question
« Reply #1 on: April 10, 2008, 09:04:03 pm »
I think you are in error. Put a witness mark on the driveshaft and a witness mark on the tire. Have an assistant rotate the tire while you observe the driveshaft.
You should rotate the tire 1 complete revolution
Offline BoobZ
« Reply #2 on: April 10, 2008, 09:12:29 pm »
been there tried that.. the driveshaft turns 1 1/3.
my only guess is that you multiply 1 1/3 x 2 because of the open differential..
maybe if i turn both wheels forward at the same time?
« Reply #3 on: April 10, 2008, 09:16:23 pm »
Yeah you need to turn the carrier not the differential.
Offline BoobZ
« Reply #4 on: April 10, 2008, 09:18:14 pm »
ahhh.. that makes sense then.. lol  ill try tomorrow and see what i come up with.. thanks :)
