Author Topic: head light switch  (Read 8595 times)
Offline hotrod24
head light switch
« on: April 21, 2008, 01:29:24 pm »
 how do you get the head light switch out of the dash is there a clip or something
1978 pontiac grand prix...
Offline 80stepsideguy
Re: head light switch
« Reply #1 on: April 21, 2008, 01:31:50 pm »
On the side of the switch there should be a pin you need to press in and pull the knob out at the same time .
thanks
pat
p.s. make sure the knob is in the off position meaning all the way in
1998 Chevy 1500 S/B 2wd
« Reply #2 on: April 21, 2008, 04:31:29 pm »
C, K, R & V MODELS
Disconnect battery ground cable.
Reaching behind instrument cluster, depress shaft retaining button and remove switch knob and rod.
Remove left side instrument cluster bezel screws, then pull outward on bezel and hold switch retaining nut with wrench,
Disconnect wiring connector, then rotate switch counterclockwise and remove from vehicle.
Reverse procedure to install.
Offline hotrod24
« Reply #3 on: April 21, 2008, 11:02:43 pm »
thanks
Offline hotrod24
« Reply #4 on: April 22, 2008, 05:12:35 pm »
as you can see i got the head light switch out and every thing out of the dash
Offline Bitzer!
  • Smiles per gallon
« Reply #5 on: May 03, 2008, 05:36:46 pm »
Hotrod, I'm confused!! You gotta column change and floor change? Whats going on!!
1979 GMC CrewCab  C20 1t
Offline hotrod24
« Reply #6 on: May 03, 2008, 09:01:15 pm »
know man it is a auto and 4wd
Offline Bitzer!
  • Smiles per gallon
« Reply #7 on: May 04, 2008, 12:58:28 am »
 :-[   lol feel a bit silly for asking that - not seen a 4x4 b4!
Offline hotrod24
« Reply #8 on: May 04, 2008, 01:01:39 am »
that is ok man
