Author Topic: dome light...  (Read 8892 times)
Offline Fordeatinz71
  • 78k miles and counting
dome light...
« on: April 23, 2008, 06:00:12 pm »
does anyone have any tips/tricks to making the dome light brighter?  i have thought about ordering a new lens (don't know how much this would help because mine looks pretty good) but i just think it doesn't have enough intensity anyhow...i know these weren't designed to put out much but this isn't enough for anything.
i thought about trying to swap in a unit from a newer truck that would accept a brighter bulb but with the curve in our roofs i just think it would end up looking crappy.  anyone else have any ideas/advice besides get a flashlight/candle...?  lol
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
Re: dome light...
« Reply #1 on: April 23, 2008, 07:41:35 pm »
Not exactly what you asked for but, I put an 1156 bulb in the socket under the dash (to light the floor up) and it lit up the whole inside of the truck better.  I dont remember what bulb is in my dome light.  Take your bulb to the store and compare bases.  If it will fit the socket and the glass part isn't too big to put the lens over (Without touching bulb to lens), you're in buisiness.
Offline 1978Bonanza
Re: dome light...
« Reply #2 on: April 23, 2008, 08:00:56 pm »
Speaking of dome lights. What is the bulb number? I need one real bad, mine never came with one and have no clue what is looks like. It is a 1978 btw.
« Last Edit: April 23, 2008, 08:03:05 pm by 1978Bonanza »
Re: dome light...
« Reply #3 on: April 23, 2008, 08:23:27 pm »
Re: dome light...
« Reply #4 on: April 23, 2008, 10:56:20 pm »
i'll have to try those Vile...
and as for the underdash sockets...i don't have 'em.  i thought they all did, but i don't seem to have them unless i've been looking over them...
Re: dome light...
« Reply #5 on: April 24, 2008, 09:45:49 am »
Unless someone removed the socket, it is right near the ashtray..  My Base truck has it.  I had one that it was crammed up under the dash...
Offline gezn2
Re: dome light...
« Reply #6 on: April 24, 2008, 05:55:44 pm »
Yeah, they get pretty dull over the years, the chromed-plastic that's supposed to act like a reflector doesn't any more :P
You could try pulling it out, taping off the bulb socket, and painting the inside of the housing bright-white or silver so you get more usable light out of the thing :)
I can't testify to how long *my* hillbilly-deluxe trick lasts, but my taillight reflectors got painted orange when some boy-racer sprayed the truck and they were dim as 'heck', I coated the inside with High-Tack and lined them with aluminum foil shiny-side-out and now they're nice and bright ;D If you're in an experimenting mood I'm not applying for any patents on the idea 8)
Re: dome light...
« Reply #7 on: April 24, 2008, 07:13:39 pm »
haha, thanks for the ideas guys. i'm gonna go look for the underdash light right now...thinking about it, i've never had a truck that didn't have it...and it'd be nice to have...even my BASE '79 Custom Deluxe had it...it didn't even have a dome light
Re: dome light...
« Reply #8 on: April 24, 2008, 08:12:09 pm »
yep, i overlooked it.  see, it's mounted by one bolt...and the bolt had loosened to the point that it basically rolled itself up into the dash.  i need to get a new bulb but then i should be in business.  the bulb LOOKS good so i'm hoping it's not a wiring problem...shouldn't be, everything else works perfect on this truck...
