Author Topic: no spark at all  (Read 5802 times)
Offline 75??? franken-trunk
no spark at all
« on: April 24, 2008, 02:05:00 am »
i have an 84 chev with a 350 and hei... i recently had a engine fire and i decided to fix it. so i replaced the wiring harness cap, rotor, coil cover, (but not the coil) and wires, and i have no spark at all, there is no interior in the truck right now could that be the problem.
Jack'em High
Fat chicks can't climb
Re: no spark at all
« Reply #1 on: April 24, 2008, 04:54:50 am »
 ??? What do you mean? Why would having no interior make you have no spark? Do you have 12 volts at the coil with the key in the on position? Why did you have an engine fire?
Re: no spark at all
« Reply #2 on: April 24, 2008, 06:21:52 am »
Did the spark control module get damaged? It will be under the dash and plugs in through the firewall behind the distributor.
Offline 79scottsdale
Re: no spark at all
« Reply #3 on: April 24, 2008, 01:57:42 pm »
« Last Edit: April 24, 2008, 02:01:06 pm by 79scottsdale »
Working on the truck with my son.........Life doesn't get any better than that!
1979 Scottsdale C10 4X4 (We are the second owner.)
Re: no spark at all
« Reply #4 on: April 24, 2008, 09:16:21 pm »
OK i replaced every thing, it runs, sorta... it backfires really bad all the wires are right, it has a edelbrock 600cfm that i cleaned out by disassembly. if i advance it it runs without backfiring until i lean the jets to tune the carb then it pops really bad again... but if i advance it any more after that it stalls out. Any ideas?
Jack'em High
Offline 78 BIG TEN
Re: no spark at all
« Reply #5 on: April 24, 2008, 11:41:50 pm »
Make sure your firing order is correct as well as your timing.
78 Big Ten, 350/350
Flowmaster..Edelbrock..MSD..Equus Gauges..Pioneer
93 Bonneville SSE
Flowmaster..CAI..HiFonics..Panasonic..Memphis 12's
00 Elantra
93 Cadillac Deville FOR SALE
Re: no spark at all
« Reply #6 on: April 25, 2008, 04:46:56 am »
This
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
Re: no spark at all
« Reply #7 on: April 25, 2008, 09:13:25 pm »
distributor 180 degrees off?
Re: no spark at all
« Reply #8 on: April 26, 2008, 05:49:55 pm »
never mind 7 and 2 were backwards
Jack'em High
