Author Topic: i guess this is one way to start the day off... fire!!!  (Read 13469 times)
Offline 75??? franken-trunk
« on: April 27, 2008, 06:44:03 pm »
Ya this is the after math of a monday morning on my way to work...
Jack'em High
Fat chicks can't climb
Offline 79scottsdale
Re: i guess this is one way to start the day off... fire!!!
« Reply #1 on: April 27, 2008, 07:18:48 pm »
That really sucks, but as long as you are okay, things are good....................the truck can be fixed.
Working on the truck with my son.........Life doesn't get any better than that!
1979 Scottsdale C10 4X4 (We are the second owner.)
Offline Fordeatinz71
  • 78k miles and counting
« Reply #2 on: April 27, 2008, 08:54:38 pm »
man, is this ANOTHER fire in the same truck?  or is this a late posting of the first fire?  do you know what caused it?
« Reply #3 on: April 27, 2008, 09:09:40 pm »
nope just a late posting and it was a newish fuel line that ruptured and hit hot stuff like headers and block... oh and please check my lights!!! post to see if you can help me out in any way what so ever...
Jack'em High
« Reply #4 on: April 27, 2008, 09:21:38 pm »
people don't realize that electrical wiring and poor fuel lines = bad news unfortunatley. Hopefully you can shed some more light on what caused your fire to help others avoid a similar circumstance.
« Reply #5 on: April 28, 2008, 05:05:40 pm »
Vile is right the first 2 thing i baught is a fire exstingiser and a batt quick disconnect, if i had the disconnect is could have prevented the second fire under the dash due to wires the melted through and shorted out in the engine bay and travled to the intearor.
Jack'em High
Offline 82chevy
« Reply #6 on: April 28, 2008, 05:57:29 pm »
dang bro thats to bad. but at least your ok and now u have an excuse to work on you truck lol
« Reply #7 on: April 28, 2008, 09:17:55 pm »
I had a Ford Econoline 350 work truck do that.  The rubber hose of Ford's design really sucked.  I can't count how many fuel lines I have bent from the fuel pump to the carb on cars/trucks I bought for resale-projects.  After being on the end of a fire I never use rubber hose under pressure.  They will eventually fail usually sooner than later...  Glad you are alright
Offline autorepr
« Reply #8 on: April 29, 2008, 07:08:22 am »
BUMMER DUDE!!!!!!   Sorry to see that happen to you.
   I just recently put a Q-jet with an electric choke on my 78 shorty and took off the partial metal cobbed with rubber line the previous owner installed and put a solid metal line from the pump to the carb. I got both off a car I scrapped and of course the metal line leaks at the pump! The flared end on the line at the pump didn't look that great when I put it on so that's what I get!! I saw it leaking while I was adjusting the carb so I shut it off and went in the house for the night. Guess after seeing your pics I made the right call.  (the exhaust is leeking at the right side manifold) I'll bend a new fuel line.
Good luck putting her back together.
Offline SUX2BU99
« Reply #9 on: April 29, 2008, 11:17:06 am »
Wow, that's really terrible. How bad is the damage to the interior and engine besides the melted interior pieces? Is it salvageable?
Does anybody make pre-bent fuel lines? Is it all that hard to make them? I played with a hand-held tube bender in college once but that was about it.
« Reply #10 on: April 29, 2008, 11:19:32 am »
Sorry to hear this, how bad is it?
inlinetube.com or classictube.com make prebent lines.
« Reply #11 on: May 01, 2008, 05:32:49 am »
the damage was extensive due to the volunteer fire dept... i think they were afraid of fire so they broke every thing to get to the one inside the truck instead of just looking under the dash like i did. that sulfur stuff is so harsh I'm telling you... i had to replace the dash pad, bezel, heat ducts, heater controls, vents, wiper/lights/tilt wheel controll stuff on the column it was bad!!! but its been 6 days and its a TV cable away from driving and an amp away from where it was if not better, i will post some pics i took yesterday...
and as for the your fuel line, there not to bad to bend,
« Last Edit: May 01, 2008, 07:34:32 am by Toolmaster »
Jack'em High
« Reply #12 on: May 01, 2008, 06:00:11 am »
almost there i wanna go for a cruise so bad... its finally warm in MN.
ps check out the sweet flamed out door panals i did...
Jack'em High
Offline SUX2BU99
« Reply #13 on: May 02, 2008, 11:23:30 am »
Nice. You don't waste any time do you??
Offline autorepr
« Reply #14 on: May 05, 2008, 07:21:46 am »
    It's not hard to bend the fuel or brake lines, I have a bender and a double flare tool so it's just time and materials. I got one on it and I'm back on the road, I trust it totally but........... the trucks got a fire ext. in it now.
   Way to go franken, lookin good!
