Author Topic: signals  (Read 5053 times)
Offline the_legend_1981
signals
« on: May 03, 2008, 05:45:00 pm »
One of my brake lights was out so i changed the bulb... it worked fine.  On my way home i went to signal and it didn't blink.  This is only happening with my headlights on. what could the problem be?
Offline Bitzer!
  • Smiles per gallon
Re: signals
« Reply #1 on: May 03, 2008, 06:07:17 pm »
Did you change it with the same type of bulb?
1979 GMC CrewCab  C20 1t
Re: signals
« Reply #2 on: May 03, 2008, 07:01:46 pm »
yeah
Offline Bitzer!
  • Smiles per gallon
Re: signals
« Reply #3 on: May 04, 2008, 01:03:05 am »
jus checking! thought I'd better start with the basics ;)
Offline DnStClr
Re: signals
« Reply #4 on: May 04, 2008, 01:12:15 pm »
You should check the signal at the connector with a test light to see if there's 12v coming to the socket intermitently when the blinker is on. If the signal is there, it has to be a problem with the bulb, as Bitzer suggests. If no signal at the socket, there may be a problem with the grounding wire right there at the socket-to frame.
Don
87 Chevy Silverado
Offline arkoza63
Re: signals
« Reply #5 on: May 12, 2008, 11:54:58 am »
does it blink with the hazards on? if not your turn switch may be the problem.
gone crazy, be back soon
