Author Topic: 2 piece driveshaft question  (Read 5329 times)
Offline KoolerSL2
  • Chevy / Ford: A house Divided
« on: May 04, 2008, 04:51:53 pm »
hey fellas.
well i just got done with the rear end lowering and must say the truck looks killer.
but i do have a bit of a snag.
i have the 2 piece driveshaft.
and the driveshaft from the trans to the hanger is as should be, pointing down.
BUT from the hanger back to the rearend is level.
i can feel a bit of binding? when i first take off.
what is the best way to remedy this problem?
raise the hanger bracket or shim the rear end?
1985 C10 LWB: gone but never forgotten
1987 R10 LWB: 107k mile near original survivor
2020 Mustang GT: 6sec 1/8mi driver
https://m.facebook.com/pages/category/Automotive-Customization-Shop/HPR-105373468425153/
Re: 2 piece driveshaft question
« Reply #1 on: May 04, 2008, 08:53:50 pm »
I made a special carrier bearing support for this. If you want one I can sell you mine for $10 bucks to cover the cost of shipping. I don't need it anymore
Offline KoolerSL2
« Reply #2 on: May 04, 2008, 11:32:50 pm »
cool!
thanks. ill get hold of you Via PM sometime this week to get your info and such.
also im going to have to torch the old one off right?
since your truck used to be a long bed i do have another question for you.
what would be the best bet for the factory bump stops in the back?
« Reply #3 on: May 05, 2008, 04:52:39 am »
I cut off my bump stops and welded them back on after I moved it back an inch. I have a set of aftermarket ones you just drill a hole and secure with a nut and bolt.
The bearing support just bolts in.
