Author Topic: Is there??  (Read 4042 times)
Offline Rockin77
Is there??
« on: May 05, 2008, 01:30:47 am »
Is there a way to get new springs for my 77 3/4 it has 9 leafs and i want 1/2 springs so it will ride smoother?
1977 GMC High Sierra 25
Re: Is there??
« Reply #1 on: May 06, 2008, 06:08:55 am »
The small amount of difference using 1/2 ton springs wont be that noticeable. You can buy brand new springs at any spring shop. They might be able to set you up with a lower spring rate steel so as not to mess with your ride hight buy using lighter duty springs or removing leaves.
