Author Topic: 700r4 transmission swap  (Read 5497 times)
Offline djknkk
« on: May 08, 2008, 10:48:43 pm »
Hi All, I have an 84 Chevy 1/2 ton shortbox 2wd with the 4sp man with the granny gear and a 3.42 rear end. Originally came with a 250 I-6 but I recently swapped in a 327.  Needless to say my mpg sux.  I am also one of those guys who is too lazy to shift.  I am very interested in swapping in a 700r4 and need your advice on what is required to do this.  I'm assuming i'll need to relocate the crossmember and get a trans cooler to start with.  Other than that I have no idea what I'm getting into with this swap.  Any advice would be greatly appreciated.
Re: 700r4 transmission swap
« Reply #1 on: May 08, 2008, 11:16:53 pm »
Few things that come to my mind.
(1) You need a 700R4 that is not computer controlled.
(2) You will need the yoke for the 700R4
(3) You will need an automatic radiator. Not a good idea to only run and aftermarket cooler. Should run through a stock one first
(4) Move the cross member as you already mentioned.
(5) Will need the throttle cable bracket with the TV cable bracket.
(6) Need a TV cable.
Offline Blue 82
« Reply #2 on: May 10, 2008, 05:42:00 pm »
That's a good start
add to the list:
7) A brake light switch out of a 700r4 equipped truck (for the converter lockup)
8) the vacuum switch for converter lockup
9) the transmission electrical plug and about 25' of #14 wire
10) some junkyard transmission steel lines for the rad and cooler
11) A 9/16 crowsfoot to get those lines on/off
12) an angle drill to drill the upper holes in the frame if not so equipped (mine wern't)
Offline treny
    • 83C10
« Reply #3 on: May 18, 2008, 04:54:46 am »
I see on the corvettes they have an adapter for a 700r4 to extend the reach to tranny about 6"  may be cheap enough to  change without moveing the transmission crossmember or if ya have a welder u cold prob make one  Bruce..
Hii There , Stating another project , an 83 c10 2wd  .Frame etc is all good and have to replace dash pad and seat , some body work and Paint Prob flat blk wth a clear cote to seal it.Ill keep in touch with updates ..Bruce
Offline ductape
« Reply #4 on: June 24, 2008, 11:00:35 pm »
where can i find a electrical to mechanical speedo converter for a swap like this?
Offline 81Cheyenne
« Reply #5 on: June 25, 2008, 09:16:30 am »
I'm going to be doing the same kind of swap. Only I'm swapping out a 700R4. Will I need to get a different length drive shaft?
« Reply #6 on: June 25, 2008, 11:21:21 am »
Why do you need an electrical to mechanical converter?  For the Speedo?   It should just be a matter of swapping out the VSS for a mechanical drive.
