Author Topic: moved  (Read 4561 times)
Offline arkoza63
moved
« on: May 10, 2008, 09:24:02 pm »
sorry it' been a while since my last post. i am now living in north west Arkansas. my burb preformed very well,only one hick-up in Wyoming. my temp gauge wasn't working when i left, on one of the passes it moved up and on then down. on the second day after a long pull the temp gauge moved up and then down, then went past hot. got off on the next exit and checked the rad. it burped and spert, the over flow bottle was full. i moved the truck to face the wind and shut it down. looked again and the lower hose was colapsed and the upper hose was starting to. then everthing went back to normal. checked the overflow bottle and it was empty, opened the cap. and it was low. added 3/4 gal. to rad. rest in overflow. temp gauge went to half and staid there. now it works fine go fig. its good to be back
gone crazy, be back soon
Re: moved
« Reply #1 on: May 10, 2008, 09:58:13 pm »
Welcome back
Offline DnStClr
Re: moved
« Reply #2 on: May 10, 2008, 11:08:59 pm »
It sounds like your coolant wasn't flowing. Are you sure the thermostat is working ok?
Don
87 Chevy Silverado
Offline 78BBSTEPSIDE
Re: moved
« Reply #3 on: May 10, 2008, 11:14:08 pm »
Gotta love Wyoming, the wind and more wind. Glad you made it to your destination.
Offline arkoza63
Re: moved
« Reply #4 on: May 11, 2008, 09:37:59 am »
the thermastat is ok, i think it was an air pocket. with the higher altitude it flash boiled. after i add 50/50 coolent all was good.
