Author Topic: New Motor?  (Read 7873 times)
Offline Unofficial
New Motor?
« on: May 11, 2008, 05:00:34 pm »
I have an '87 Custom Deluxe with a 305 TBI, and I'm looking for a 350 to drop in. I found one for $850 on craigslist. The ad said it was baked and blasted, bored .040 over, and for the cam: 204 intake ,214 exhaust duration @.050
I was looking at another one, and it was a two bolt main. How big of a differnce would it be between a 2 and 4 bolt main? Should a avoid a 2 bolt?
Thanks guys :)
« Last Edit: May 11, 2008, 08:21:02 pm by Unofficial »
1987 Custom Deluxe R10
350 TBI bored .040 over
MSD ignition
Offline cky686
Re: New Motor?
« Reply #1 on: May 11, 2008, 06:08:14 pm »
2 bolt can still handle some serious power. i wouldnt be worried about it.
Re: New Motor?
« Reply #2 on: May 11, 2008, 08:29:37 pm »
There's nothing worng with a 2 bolt. I wouldn't hesitate to build a 2 bolt 350. In fact I've seen more 4 bolt main failures than 2 bolt.
Offline Unofficial
Re: New Motor?
« Reply #3 on: May 11, 2008, 08:40:02 pm »
I found another one on craigslist, but I think I want the bored over one just because then I won't complain about not having a bored out engine later down the road ;D
MSD ignition
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
Re: New Motor?
« Reply #4 on: May 11, 2008, 10:31:59 pm »
Quote
Having a bored engine is not all that advantageous.  Sure you increase the displacement slightly, but, if it is bored out over .30, that just means in the future, to smooth out the bores upon next rebuild of the block, you won't be able to bore it out too much more.
Offline Unofficial
Re: New Motor?
« Reply #5 on: May 13, 2008, 09:29:39 am »
I found the one I'll be buying. I'm pretty sure it runs, but if not that's okay. The guy is going to let it go for $100. My dad has rebuilt tons of motors, so it's going to be a father/son project. I might paint the inside of the engine compartment when I pull the 305, to make it look nicer.
MSD ignition
Offline Lt.Del
  • Andy aka:SgtDel
    • www.delbridge.net
Re: New Motor?
« Reply #6 on: May 13, 2008, 11:29:03 am »
If you are rebuilding a 350, make it a 383!
Offline Unofficial
Re: New Motor?
« Reply #7 on: May 13, 2008, 11:44:13 am »
It would be wonderful if you could explain to me how I would add 33 to my displacement ;)
MSD ignition
Offline eventhorizon66
Re: New Motor?
« Reply #8 on: May 13, 2008, 12:08:49 pm »
A 383 is a 350 block with a 400 crankshaft (3.75" stroke).  There are tons of stroker kits out there for a wide variety of budgets.  Here's a bit of info: 383 Stroker FAQ.
'85 C10 SWB 350 700R4 TKO600
Offline Blue 82
Re: New Motor?
« Reply #9 on: May 13, 2008, 08:13:30 pm »
Swaping from a 305 TBI to a 350 TBI will require some upgrades
google the 305 to 350 swap before you get too deep into it
it's not a plug and play deal (it is if you do the right upgrades, research before you wrench)
Fueling a 383 TBI is tricky to say the least
On page 3 he gets it running
http://www.fullsizechevy.com/forums/general-discussion/performance/233389-383-tbi-buildup-lots-pics.html
Offline Lt.Del
  • Andy aka:SgtDel
    • www.delbridge.net
Re: New Motor?
« Reply #10 on: May 13, 2008, 10:55:32 pm »
I love my stump puller stroker engine
http://www.delbridge.net/install
