Author Topic: np203 help  (Read 4181 times)
Offline 76 k10
np203 help
« on: May 17, 2008, 05:35:12 pm »
ok is the np203 transfer case a pain in the butt to put it ??? cuz on my other truck it has a np205 and it was real easy but this 203 is kicking my butt
Re: np203 help
« Reply #1 on: May 18, 2008, 12:38:53 pm »
It's heavy but not hard to put in. What's the problem?
Offline gezn2
Re: np203 help
« Reply #2 on: May 20, 2008, 11:18:21 am »
I'm not sure what you're asking here :-\
I'll take a guess that you might be having 'fun' with the shifter?
The shifter on our 203s was flaky from the factory, they don't hold up to dirt and/or rust very well :(
That shifter is moving two completely different linkages, and it can be a real bear to deal with when crud builds up, I'm going to have to work over the one on *my* '76 K10 eventually :P
You might be able to free up the linkage by soaking it with lube, but sometimes you've got to tear it out and polish out the rust >:(
There are 'twin stick' kits out there that completely sidestep the whole problem, I'm just too cheap to go that way until I *have* to ;D
