Author Topic: Pulley Squeal?  (Read 6322 times)
Offline Mamby
Pulley Squeal?
« on: May 22, 2008, 02:27:13 pm »
Whenever i start my truck up it usually squeals for about a second then it stops, but now, it does it when im driving. I dont think its the belt because ive put belt dressing on it. I think it might be a pulley bearing? any ideas?
Offline ccz145a
Re: Pulley Squeal?
« Reply #1 on: May 22, 2008, 02:59:17 pm »
it's the belt. get a new one... dressing never works for long.
Re: Pulley Squeal?
« Reply #2 on: May 22, 2008, 04:20:40 pm »
Ditto, never use dressing, just replace the belt.
Offline HAULIN IT
Re: Pulley Squeal?
« Reply #3 on: May 22, 2008, 04:28:00 pm »
Mamby, Yes, change the belt. Also run a piece of 180-220 grit sand paper on the pulley grooves. If the vehicle has been sitting for a little while, a minimal  rust build-up can form on the exposed parts & cause the squeal. Lorne
Offline Mamby
Re: Pulley Squeal?
« Reply #4 on: May 22, 2008, 08:52:53 pm »
ah, found out what it was, alternator belt was loose, go figure, the only belt i didn't check.
Offline the_legend_1981
Re: Pulley Squeal?
« Reply #5 on: May 22, 2008, 08:57:44 pm »
Same thing just happened to me
Offline Stewart G Griffin
Re: Pulley Squeal?
« Reply #6 on: May 23, 2008, 09:50:32 am »
i just went thru this ordeal 2 months ago;
Not only get a new belt, but get a Gates belt;  That Dayco stuff won't cut it.
Please refer to this thread regarding my plight:
http://forum.73-87chevytrucks.com/smforum/index.php?topic=5454.msg26521#msg26521
Re: Pulley Squeal?
« Reply #7 on: May 23, 2008, 09:54:43 am »
UPDATE:
Ok, i see it was that the belt was loose.   Anyways, i feel my thread is good reading anyways.
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
Re: Pulley Squeal?
« Reply #8 on: May 23, 2008, 10:46:15 pm »
Clean the pulleys, sometimes they get oil on them that never goes away on it's own.  Loose will do it too ::)
