Author Topic: A/C Removal  (Read 10273 times)
Offline day1
A/C Removal
« on: May 25, 2008, 10:38:03 am »
1974 C10 1/2 Ton and a minimalist owner
So I'm going through my truck to clean it up and simplify as much as I can. Re wiring, removing unnecessary components etc...
A/C didn't work and is going. I have removed the compressor, the brackets, the condenser, all the lines, and even pulled the evaporator from the "firewall box" (?proper name?) and this brings up my question. I assume the non AC trucks had a smaller box with no provision/room for an A/C evaporator... If this is the case, where can I get said box? L"M"C has all the A/C or Heater parts you need, minus these boxes. They even show the boxes in their diagrams but show no part # or availability. Are these boxes available to purchase or is it off to the junkyards for the hunt?
« Last Edit: May 25, 2008, 10:41:43 am by day1 »
Re: A/C Removal
« Reply #1 on: May 25, 2008, 10:46:47 am »
I put the AC delete box in my 74 GMC. There's pix in my thread of it here http://forum.73-87chevytrucks.com/smforum/index.php?topic=5723.135
here's the cover
http://www.acdelete.com/pages/73-90_Truck.htm
Offline day1
Re: A/C Removal
« Reply #2 on: May 25, 2008, 01:14:08 pm »
Right on, thank you for the reply. Seems a bit pricey, but you have to pay to play. :)
Your engine bay looks tasty.
I assume a used box though from a non A/C truck is similiar?
Offline dumbucket1
  • Too Many Trucks
  • Coal Hauler
Re: A/C Removal
« Reply #3 on: May 25, 2008, 03:04:21 pm »
a heater box from a non a/c truck will not bolt in place of that a/c box.
