Author Topic: Frame mounting for Z-bar picture?  (Read 15118 times)
« on: May 27, 2008, 03:32:43 pm »
Does anyone have a picture of their frame bracket and z-bar assembly with measurements on the length of the z-bar?  I am putting together my extras for the local swap meet next month and don't want to mislead anyone.  I parted out this mid 70's truck several years ago of all the stick conversion stuff and from what I remember it is correct.  I took out the steering column, pedals, rod to the z-bar, frame bracket and z-bar. All I have is the hydraulic setup up on my mid 80's to compare it to.  Thanks in advance.
Re: Frame mounting for Z-bar picture?
« Reply #1 on: May 27, 2008, 04:20:14 pm »
Do you mean for the clutch?
« Reply #2 on: May 27, 2008, 04:52:40 pm »
Yes, looking for actual pics to compare with mine to make sure what I have is from a Chevy.  I have parted out many vehicles over the years and don't want to give anyone the wrong stuff.  I did part a Ford truck out once but don't think I took the clutch stuff, just the tranny which I sold right away.  Thanks.
« Reply #3 on: May 27, 2008, 05:07:18 pm »
Post I pic, I can identify it for you.
« Reply #4 on: May 27, 2008, 09:12:56 pm »
I will get one tomorrow, Thanks
« Reply #5 on: May 28, 2008, 07:56:44 pm »
Chris, here is a couple of pics.  Also what years did they have the older splined end on the steering column shaft?  Thanks in advance.
« Reply #6 on: May 29, 2008, 02:26:47 pm »
That is the correct ones for the pre-83 mechanical setup.
« Reply #7 on: May 29, 2008, 03:20:11 pm »
Thanks for the info.  Do you know when GM went to the current steering shaft as opposed to the splined version?
Offline 1976Scottsdale
« Reply #8 on: May 30, 2008, 07:11:19 pm »
My 78 is/ was splined, my Dad's 79 is not.
« Reply #9 on: May 30, 2008, 10:34:46 pm »
Cool, thanks so 73-78, then 79-83 and 84-87 for the integrated wiper/dimmer.  I appreciate the response back.
« Reply #10 on: June 02, 2008, 02:37:50 pm »
Sorry, missed that question completely...
