Author Topic: six liter swap  (Read 19618 times)
Offline buriesjeeps
six liter swap
« on: May 28, 2008, 01:19:03 am »
Well to start with I sold my 5.3 and got a bigger 6.0 and I have one major question, I've seen these stand alone harness kits that work for motor swaps from the newer ls series trucks that run the ecu so I dont have to tear apart the harness my question is has anyone heard of or had any good or bad experiences with these.
This is the one I am looking at:http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=330239643181
thanks to any and all replies
Offline DnStClr
Re: six liter swap
« Reply #1 on: May 28, 2008, 09:35:48 am »
Pretty enticing price when you compare to a Painless harness at $400+. I notice that all the wires are the same color,and it doesn't say if the're tagged or not. But still, the price is so good- it might not be a bad buy.
Don
87 Chevy Silverado
Re: six liter swap
« Reply #2 on: May 28, 2008, 10:07:40 am »
check his feedback
Offline eventhorizon66
Re: six liter swap
« Reply #3 on: May 28, 2008, 10:22:26 am »
Looks funky.  But if it works, it's got to be the best deal out there.  When I was considering the 6.0 swap I was gonna to go with Nelson Performance for a custom harness.  They are not cheap by any strech of the imagination, but look super clean and I know lots of people on LS1trucks.com that have great things to say about them.  BTW you should also be a checking with the guys on the above forum for advice as you perform this swap.  There's a conversions section dedicated to LS swaps.  Not saying that the pros here can't help you, but you should always try to draw from the largest pool of knowledge available.
'85 C10 SWB 350 700R4 TKO600
Re: six liter swap
« Reply #4 on: May 28, 2008, 01:17:04 pm »
Its a rip off, you still have to have a harness for this to work, and you still have to manipulate it for this to plug in.  If you are going to do that it would be easier to just remove what you don't need...   If you got the motor, you should have gotten the harness and ECM for it.
Quote
Harness: (You have to rework your own harness to get this ready to add on, this controls power and more to the harness and computer)Designed to convert your Engine Harness Stand-Alone for most Swaps(Stand-Alone is where you can put your engine in any vehicle and all you have to hook up is power, ignition, and ground wires)
Offline buriesjeeps
Re: six liter swap
« Reply #5 on: May 29, 2008, 12:26:48 am »
the new motor has the ecu and complete harness I just figured it would be easier but if that wont work oh well.
Re: six liter swap
« Reply #6 on: May 29, 2008, 02:21:10 pm »
I am not saying it "won't work" but I don't see what you are going to gain if you still have to rework the existing harness.
Offline bowtieguy
  • Country as a Cow Pie
Re: six liter swap
« Reply #7 on: May 30, 2008, 03:42:14 pm »
I can send you my spread sheet, I have all the wires you need to keep labeled.  You can wire it your self for nothing.  I did mine this way.
Even if you get a Painless or a Speartech harness, you will need to send your ECM to some one who can reprogram it for you.  There are a number of people that can do this for you.
here is my email. bowtie_or_nothin@yahoo.com
If you don't want to do it your self, send it to Spear Tech.  John is top notch and does perfect work.  He reflashes ECM's as well.
http://www.speartech.com/
« Last Edit: May 30, 2008, 03:45:26 pm by bowtieguy »
Toys:
89 Black Lesabre T 62k miles
03 Lesabre Celebration Edition
08 NNBS CC Z71 LTZ
79 Flat BlackChevy C-10  5.3/4L60E
Offline buriesjeeps
Re: six liter swap
« Reply #8 on: June 01, 2008, 12:49:41 pm »
That would help out alot. What all should I have removed from the ecu as well. Thanks guys
Offline bowtieguy
Re: six liter swap
« Reply #9 on: June 02, 2008, 08:00:02 am »
email sent.  You will have all of 6 hours in your harness, if you take your time, maybe longer.  Lay it all out and try to label everything the best you can.  Take off all of the lume and tape.  The plugs that go into the computor come apart.  If you look at it, you can easily figure out how to remove each wire you don't need from the red and blue plugs.  They come out through the bottom so you will have to snip each wire to get it fully removed.  Give you self a foot or so on most, you will need a few wires you remove from the red and blue pins to add back in.
Let me know if you have problems, or have questions about what I sent you.
Toys:
08 NNBS CC Z71 LTZ
Re: six liter swap
« Reply #10 on: June 02, 2008, 10:59:30 am »
Bowtie, care to share the spreadsheet with the rest of the community?  I have had others asking for something like that.
Offline bowtieguy
Re: six liter swap
« Reply #11 on: June 03, 2008, 08:30:50 pm »
I could probably do that.  Can I send it to you and you post it?  Not sure how to post a file.
Toys:
08 NNBS CC Z71 LTZ
Re: six liter swap
« Reply #12 on: June 03, 2008, 11:33:09 pm »
Yeah, shoot it to me and I can post it.  You can upload it via the additional option tab.
Offline buriesjeeps
Re: six liter swap
« Reply #13 on: June 06, 2008, 01:10:53 pm »
Wiring is done... now the transmission (th350) how can I tell if my engine has the long crankshaft or if i need to buy the crankshaft spacer?
Re: six liter swap
« Reply #14 on: June 06, 2008, 01:34:45 pm »
All cranks are the same length.  Stock LS flexplates for 4L60E's have a slight dish to them.  You will need a spacer for your TH350.
