Author Topic: What exactly did this? (trans help?)  (Read 3913 times)
Offline Donut
« on: May 28, 2008, 07:44:09 am »
The rustbucket in my sig is the problem child.
My tranny is toast (I believe) no forward gears, reverse only.  I have started digging into the truck to get ready for a tranny rebuild and motor swap.
I drained the transfer case and noticed it was a gear oil-atf mix!  I can only assume the tranny was pumping atf into the transfer case.  Could anybody tell me what is a likely cause of this?  And maybe any weak spots in the turbo-350 I need to address when i have it apart?  (It's a plow truck, not a high HP street rod.)
'73 Chevy K-20 ***SOLD***
350/tbh350/np205
'86 C-30 dually, 454/tbh400
Re: What exactly did this? (trans help?)
« Reply #1 on: May 28, 2008, 08:53:46 am »
If the input seal is gone on the transfercase it will drain out of the trans into the transfercase. Try topping off the A/T and see if it gives you back your gears. If it's good then just drop the transfercase and replace the seals.
Offline Donut
« Reply #2 on: May 28, 2008, 02:51:10 pm »
Thank you kind sir.  I'll give it a shot when everything goes back together.
350/tbh350/np205
Offline DirtyLittleSecret
« Reply #3 on: May 28, 2008, 10:05:33 pm »
I'll add that my old 1965 Jeep/Kaiser did just this about 5 years ago when my seal went out.  Pulled the x-case, drained the AT, fixed the seal, and refilled.  No problems since.  A pretty common situation it seems.  Does anyone know whether there's a bomber seal for this problem?
78 K20: fresh 350, SM465, NP205, 4" Pro Comp, & working hard!
65 Jeep J300: 13.5:1 383, TH400, NP205, mostly NOS.
88 Toylet LandCruiser FJ62: LT1, 4L60e, 3" OME, Aussies.
06 VW TDi: DD@72mpg.
