Author Topic: Removing rivets from rear hangers 1983 c10  (Read 10457 times)
Offline GVazquez
« on: May 28, 2008, 10:31:58 pm »
Im about to drop the rear of my 83 with shackels and hangers. What are you guys using to rivets on the hangers? I dont have access to a torch,... any help is appreciated.......... Gabriel
Offline Redneckchevy
    • Photo Bucket
Re: Removing rivets from rear hangers 1983 c10
« Reply #1 on: May 28, 2008, 11:11:19 pm »
I used a  grinder.. with a good cut off wheel....
« Reply #2 on: May 29, 2008, 05:53:37 am »
In the past I have used a cold chisel for every rivet on a frame. Swapped them all over to another frame. Took a heck of a long time but it worked! Only smashed eleven of my knuckles!
Offline HAULIN IT
« Reply #3 on: May 29, 2008, 09:03:50 am »
GV, The ideal & fastest method is a torch & a good air chisel, warm up head & chop. Since thats not really an option for you. The grinder will work, but your going to eat allot of grit & sparks. A GOOD air chisel will probably be easier & allot less sparks. Knock the heads off & use a pointed chisel to push out the center. Use grade 5  bolts & nuts when reinstalling the parts. Cut the bolts an 1/8" from the nut & peen over the threads so the nuts wont back off. Lorne
« Reply #4 on: May 29, 2008, 12:10:03 pm »
I always replace them with Grade 8 bolts...
« Reply #5 on: May 29, 2008, 10:50:27 pm »
I agree I use grade 8 bolts for anything to do with frame or suspension.
Offline dunedigger
« Reply #6 on: May 30, 2008, 07:09:16 pm »
I use a air chisel lately but have used a angle grinder a lot.  Back in the day I picked up a chisel with a hand guard so when I missed it didn't hurt so bad  ;D The one thing I don't like about the air chisel is if it gets away from you, it can leave some nasty marks on the frame.  I have drilled a ton of them too but have to sharpen the bits a lot.  I think the best way always seemed to be to drill them with 1/4" bit and then buzz them with the chisel.  I always use grade 8 also.
Offline static22
« Reply #7 on: May 30, 2008, 09:38:11 pm »
Sounds like fun either way. I agree with the majority on the bolt grade selection, especially for suspension.
See if you can bust 12 knuckles and beat Blazins record!
Offline comp
  • 76-77-78
« Reply #8 on: May 30, 2008, 11:34:51 pm »
grinder
