Author Topic: What is the Best Rod Length for a 383?  (Read 22784 times)
Offline 81Cheyenne
« on: June 06, 2008, 09:39:17 am »
I'm building a 383 for my C10. Is it better to use 5.7" or 6" rods?  I have a chance to buy a new crank that uses 6" rods at a reduced price and wanted opinions on rods before I bought it. I'll be buying new rods either way whether I get this crank or not.
Re: What is the Best Rod Length for a 383?
« Reply #1 on: June 06, 2008, 10:16:33 am »
You'll never notice a difference performance wise. Hardcore racers like to go with a longer rod due to dwell and thrust angle but for a street engine just go with the most affordable balanced rotating and reciprocating assembly.
Offline nico
« Reply #2 on: June 06, 2008, 11:22:05 am »
I have 5.7" rods in my 383 and will go with at least 6" next time...  Often times you either have to clearance the rod bolts or get a reduced-base circle cam (that's my choice) and corresponding pushrods with the 5.7's...  For the money, check into building a 396 small block. Just a little more stroke than a 383, but quite a bit more power.
White 1984 Silverado - Factory Paint, Factory Interior, and only 25k miles...
SOLD - Tan 1984 Silverado - 383, 700R4, Detroit Locker & 3.73's...
« Reply #3 on: June 06, 2008, 11:45:32 am »
What are you building the truck for, a drag truck or street?  For the street, you won't be able to tell the difference as most of you driving will be spent between idle and 2500rpms.
Offline 81Cheyenne
« Reply #4 on: June 06, 2008, 12:10:44 pm »
I'm building the truck for the street. I'll be using it for hunting and fishing. Pulling a boat (occasionally with a slide-in camper on the back), hauling my motorcycle,goofing around,etc. I like the idea of the torque that a 383 will give me on hills,boat ramps and so forth while pulling some weight.
« Reply #5 on: June 06, 2008, 12:38:14 pm »
If that is the case, I would build the cheapest rod configuration and put the money elsewhere for longevity/dependability.
« Reply #6 on: June 06, 2008, 12:42:57 pm »
Yep just go with what's most cost effective. If you buy a matched set you most likely won't have any major clearance issues and the cost will be much lower. I'll be building another one very soon with some Vortec heads. I will post the whole build when I do it but I'm also going to go the more cost effective route.
Offline Blue 82
« Reply #7 on: June 06, 2008, 01:54:03 pm »
Some pistons (for 6" rods)  have the pins running through the oil ring area
Offline Blue 82
« Reply #8 on: June 06, 2008, 09:06:14 pm »
here's a good article from many years ago
it gives a few tips on how to get a handle on detonation
I think this article is more important now, with the price of fuel heading toward the sky.
a few bucks spent on machine work and attention to detail will pay off in the long run.
http://www.chevyhiperformance.com/howto/47075/index.html
here's a torquey 383 that might be of interest
http://www.chevyhiperformance.com/techarticles/148_0207_ht_383_chevrolet_crate_engine_build/index.html
Offline comp
  • 76-77-78
« Reply #9 on: June 18, 2008, 11:44:22 pm »
i'm going to use 5.7's
Offline 81Cheyenne
« Reply #10 on: June 19, 2008, 08:44:17 am »
Speaking on detonation....(Maybe I should start a new thread what do you think Capt?)...I'm probably going to go with 6" rods since I picked up a SCAT 9000 that uses them.  I have had conflicting opinions (from guys whose opinions that I trust) on whether I should go with flat top pistons or a dish.  I'm using 64cc vortec heads. On second thought, I WILL start a new thread on this one.
« Reply #11 on: June 19, 2008, 10:13:30 am »
Just calculate your compression ratio. Figure out which pistons you have available and find out what the -cc volume is
Offline 81Cheyenne
« Reply #12 on: June 19, 2008, 12:25:39 pm »
Yup. Done that already.  I guess the question is what's the max compression ratio that will run on pump gas and still give me plenty of power with this setup(vortec,383,C10,etc)?
« Reply #13 on: June 19, 2008, 12:28:50 pm »
I would strive to stay at or near 9:1 unless you are going with aluminum heads.  By pump gas are you talking about 87 or 92?  I would build it to run on 87 it it were mine.
Offline Blue 82
« Reply #14 on: June 19, 2008, 03:54:42 pm »
Using a flattop with 64cc heads with a .030" over piston .025" in the hole will put you at 9.8:1 with a -5cc flattop with a .040" gasket
If you zero deck it it's close to 10.8:1
Deck it .015" and use a dished slug for better detonation resistance... with the piston .010" in the hole that gives you .050" piston to head clearance with a .040 gasket.
some people say that .050" piston to head is tight, but I've run the slugs .003" above the deck with a .039" gasket with no problems in a 383 for a Ski Boat. You gotta use hypereutectic pistons for that, and keep the piston to wall clearance tight.
