Author Topic: Cross over pipe worth it?  (Read 10789 times)
Offline gbskunk2006
« on: June 13, 2008, 05:57:44 pm »
I have a 2 1/2 inch dual exhaust setup on my 86 GMC C15 with a 4.3 Liter V6.  Will adding a cross over (i.e. H-Pipe or X-Pipe) really make a big difference in;
1) Horse Power?
2) Torque?
3) Sound?
Thx in advance?
« Last Edit: June 14, 2008, 12:50:01 am by gbskunk2006 »
86 GMC C15, 4.3 Litre V6, TH400
http://forum.73-87chevytrucks.com/smforum/index.php?topic=6879.0
90 Toyota SR5 4X4 Ext Cab V6 5 speed
99 Toyota Solara SLE
Re: Cross over pipe worth it?
« Reply #1 on: June 13, 2008, 07:46:31 pm »
T answer 1 and 2, I don't think it will make any difference. You already have an overkill exhaust as is, maybe too much. As for the sound, the x pipe tones the exhaust down, and gives it a more balanced sound. Don't know about the sound on the six with an x pipe, but I DON'T like them with straights, so it may make it sound better, but performance wise, it won't make enough difference to justify the cost. But, just think, when you swap in that hi-po smallblock, the exhaust will already be done. ;D
Offline Blue 82
« Reply #2 on: June 13, 2008, 08:58:11 pm »
I put an "H" pipe on my 350 truck and noticed a slight increase in low/mid torque judging from the SOTP meter
I don't have any before/after timeslips to verify a gain/loss in HP though.
I did experiance a nice reduction in noise
Here's some cool X pipes from Burns Stainless
« Reply #3 on: June 13, 2008, 10:14:07 pm »
You don't have a 4.6L If it's a v6 it's a 4.3L
Offline eventhorizon66
« Reply #4 on: June 14, 2008, 12:47:13 am »
I experienced a noticeable increase in low end torque and a decrease interior resonance when I added an h-pipe to the custom straight dual exhaust on my old '99 Suburban.  Well designed x-pipes are supposed to be beneficial at all rpms/loads, but are more expensive and likely not a significant improvement over an h-pipe on a 4.3L.
'85 C10 SWB 350 700R4 TKO600
Offline Dragon
« Reply #5 on: June 14, 2008, 01:34:40 am »
As Chop pointed out, your 2.5 System is overkill for a Six Shooter no matter how you cut it....   Adding a Cross-Over H-pipe should give you some of the power back, but the Sixer is having trouble Huffing through such big lungs...   Generally a 2" would be prefered, but a 2.25" would be slightly pushing it....   Now if you had a single outlet exhaust system, 2.25 to 2.5" would allow that six to breath like it had a 2"-2.25" dual system....
The Best actual Cross Over design, is a True X- Pipe(Such as what Blue has suggested)...  Old School H-Pipe cross overs won't be as beneficial as an X, as they create more of a Pressure Bumper between the two sides....   Ofcourse H-pipes are Generally prefered to not having a Cross Over Pipe at all, when it comes to applications that lack the ability/room to run a True X-pipe...
Dragon
08 Magnum-New Toy
96 Caprice 9C1-Who Knows
96 GMC ECLWB & 92 Chevy ECLWB
Offline gbskunk2006
« Reply #7 on: June 15, 2008, 11:45:07 am »
Well, I decided to go for it.  IMO it's improved the low end torque and the sound is a little deeper, but actually quieter inside the cab.
This is my SOTP meter test:)
Improved low end torque;
-from idle (without giving extra gas) it will slowly "crawl" up a hill with about 6-8 degree incline.
-seems to maintain it's cruising speed longer once I take my foot off the pedal.
Deeper Sound;
-just stood outside the cab when idling.  Now let's see if the neighbors notice when I leave for work a 5AM :)
Sorry, no dyno test in-store for this six shooter :)
« Reply #8 on: June 16, 2008, 01:25:55 pm »
Was it an H-pipe you ended up adding to your current system?
Offline comp
  • 76-77-78
« Reply #9 on: June 17, 2008, 06:19:06 pm »
got any pics of your system ??
Offline gbskunk2006
« Reply #10 on: June 18, 2008, 11:14:03 pm »
It was the H-pipe.
Sorry, I should have taken some photos while she was up on the hoist.  The guys that did the work do a lot of custom exhausts so all I can say is that they did a real clean job!
http://forum.73-87chevytrucks.com/smforum/index.php?topic=8625.0
Offline comp
  • 76-77-78
« Reply #11 on: June 18, 2008, 11:43:19 pm »
 you can add them later  ;D
Offline SUX2BU99
« Reply #12 on: June 19, 2008, 11:03:12 am »
Who did the work?
Offline gbskunk2006
« Reply #13 on: June 19, 2008, 10:55:37 pm »
These guys originally installed my duals so I went back to them for the cross over pipe.  Only charged me $80.
http://www.quietmufflerandbrake.ca/
Cheers
