Author Topic: transfercase leaking from rear seal  (Read 4084 times)
Offline plowking_90
« on: June 14, 2008, 10:25:46 am »
 brand new seal still leaks looks like it coming from where the drive shaft goes in any help
Re: transfercase leaking from rear seal
« Reply #1 on: June 14, 2008, 12:32:13 pm »
Clean up the the shaft with some emery cloth. When you replace the seal make sure you pack the lip of the seal with some petroleum jelly.
Offline plowking_90
« Reply #2 on: June 14, 2008, 01:14:17 pm »
WHAT ECACTLY IS EMERY CLOTH???
« Reply #3 on: June 14, 2008, 01:16:00 pm »
It's a fine type of sand paper for polishing metal.
Also make sure your drive line angles are correct and your output bushing is in good shape.
Offline HAULIN IT
« Reply #4 on: June 14, 2008, 03:10:52 pm »
Plowking, Can you see/feel a groove on the yoke where the seal has been riding? How much yoke is slid into the transfer case?
