Author Topic: 350 to 454  (Read 5934 times)
Offline 82chevy
350 to 454
« on: June 15, 2008, 03:51:25 pm »
hey guys i have some questions. i have a 82 chevy with a 350 that was already swapped to tbi. it raps pretty bad and its time for a new engine. i know someone with a 454 tbi that supposedly runs great. what do i need to get to swap this motor into my truck now. im guessing BBC motor mounts? but what else? any help will be great
Re: 350 to 454
« Reply #1 on: June 15, 2008, 05:53:17 pm »
The mounts are the same. The wiring harness and computer would be helpful. Flexplate, exhaust, radiator, hoses, pulleys etc. That's where you'll have to make some changes.
Offline dumbucket1
  • Too Many Trucks
  • Coal Hauler
Re: 350 to 454
« Reply #2 on: June 15, 2008, 06:27:59 pm »
I went backwards on a carbed truck, only had to have my existing exhaust hooked up to the 350 and had to put a small block power steering pump on. Everything else I reused from the 454.
Offline txtj79
  • 1980 Chevy C-10 SWB
write-up
« Reply #3 on: June 17, 2008, 08:58:34 pm »
Does anyone know of a write up or more detailed description on doing this in one of our trucks?  I have a line on a good running 454, carbed, alreday mated to a TH400.
Thanks,
T.J.
Re: 350 to 454
« Reply #4 on: June 17, 2008, 11:59:06 pm »
How detailed do you want?  It is just a matter of taking a SBC out and putting a BBC in, save for a few specifics.
Offline frogman68
Re: 350 to 454
« Reply #5 on: June 18, 2008, 02:27:22 am »
If its 2wd wont the coils need to be swapped ??
Offline werewolfx13
Re: 350 to 454
« Reply #6 on: June 18, 2008, 07:58:02 am »
ought to be so as to not affect the ride height and handling, course you can also install coil spring air helpers and use those...
Chris
'83 Chevy c10 Silverado SWB
Offline txtj79
Re: 350 to 454
« Reply #7 on: June 18, 2008, 10:20:54 am »
Well, I don't really have any experience with big blocks.  I mainly would like to know what parts I would need to change out in order to make it work.  Or is Vile's list above pretty much it?
Thanks,
T.J.
Re: 350 to 454
« Reply #8 on: June 18, 2008, 10:57:23 am »
Viles list is pretty much accurate.  If you have a complete running engine/trans assembly, you don't need to worry about the flexplate.  The exhaust is different.
As for coils, it will lower the truck about 1".
Offline ccz145a
Re: 350 to 454
« Reply #9 on: June 18, 2008, 11:30:11 am »
Quote
If you keep the original coils, your alignment will change. I ruined a front set of tires after a 305 --> 396 swap and a 300mi drive.
The power streering bracket is the hardest thing to get.
Offline txtj79
Re: 350 to 454
« Reply #10 on: June 18, 2008, 12:05:46 pm »
Ok, thanks guys.  I think I'm gonna jump on this.
-T.J.
Re: 350 to 454
« Reply #11 on: June 18, 2008, 04:24:03 pm »
Start a new post with what you are doing and add some pics and you can create a how to on how to.
