Author Topic: cab mounts  (Read 7308 times)
Offline Bitzer!
  • Smiles per gallon
cab mounts
« on: June 16, 2008, 11:42:03 am »
Another Q for you guys out there! I'm thinking of replacing the cab mount rubbers on my crewcab but unsure which to get. I haven't really got to find out if its a 1/2t or 3/4t or do both rubbers fit?
1979 GMC CrewCab  C20 1t
Offline dunedigger
Re: cab mounts
« Reply #1 on: June 16, 2008, 08:40:25 pm »
73-87 have different mounts than than 81-87.  73-87 2wd and 4wd are different set.  I think 81-87 are all the same.  There is no difference between 1/2 and 3/4 ton.  Someone correct me if I'm wront but that's what I have dealt with thus far.
Re: cab mounts
« Reply #2 on: June 16, 2008, 10:50:03 pm »
Sounds good to you!
Re: cab mounts
« Reply #3 on: June 16, 2008, 11:20:44 pm »
What exactly is different from 73-87 from 81-87??? Do you mean 73-80 is different than 81-87?
Offline Bitzer!
  • Smiles per gallon
Re: cab mounts
« Reply #4 on: June 17, 2008, 11:19:26 am »
 you've all lost me now!!
are we saying a "rubber" set for a 2wd 73-80 will fit my '79 regardless of 1/2t or 3/4t?
Re: cab mounts
« Reply #5 on: June 17, 2008, 12:19:22 pm »
73-80 and 81-87(91) are different
This is for pickups only: (from what I have found)
73-80
2WD 1/2T ONLY
2WD 3/4T and 1T are the same
4WD 1/2 - 1T are the same
81-87
2WD 1/2T ONLY
Offline Bitzer!
  • Smiles per gallon
Re: cab mounts
« Reply #6 on: June 17, 2008, 01:07:44 pm »
cheers Chris but is mine a 1/2t or 3/4t lol  i really dont know!!
Re: cab mounts
« Reply #7 on: June 17, 2008, 01:17:09 pm »
Crew cabs were only available in 3/4T or 1T.
Offline Bitzer!
  • Smiles per gallon
Re: cab mounts
« Reply #8 on: June 17, 2008, 02:36:28 pm »
 8)
Absolute diamond!!
cheers
