Author Topic: Another q-jet question  (Read 3014 times)
Offline BeaverBanker
« on: June 17, 2008, 11:48:28 am »
350 with t-350 tranny.
When you gun the the engine, It takes off prime. You can get all the way up to 55 but then you have to burp the throttle other wise it will stall right out. Any ideas?
Im going to switch carbs with a buddy to try his, i suspect it won't happen with his carb
1985 Chev K20 350/465/205, 44/14FF, 9" lift with 37's, Roll Bar, Winch & 70's Front Clip
1999 Silverado 1500 - Daily driver
Re: Another q-jet question
« Reply #1 on: June 17, 2008, 01:50:35 pm »
Sounds like fuel starvation. Check your fuel pump and all of your lines first.
