Author Topic: well, in light of gas prices...  (Read 5465 times)
Offline Fordeatinz71
  • 78k miles and counting
« on: June 20, 2008, 12:53:40 pm »
i am thinking about going a different route with my engine plans. i had planned on building my 350 into a 383 and putting it in, which would have made a STOUT motor, but a VERY fuel-thirsty one at that. well, i have always loved mixing new and old and thought i would jump on the "lets put a 5.3 in my 73-87" bandwagon. i know i can do some moderate modification and i'll have almost as much power as i was gonna have with my 383 and i'll still get better fuel mileage. now i just have to sell my 350. i found a rebuildable 5.3 for $300 and the same place sells ECMs for $25. so i am pretty sure i'm gonna go that route and then just build a stout lil 5.3...thoughts?
Offline TexasRed
Re: well, in light of gas prices...
« Reply #1 on: June 20, 2008, 01:11:30 pm »
I'd try to get everything, engine, trans, alternator and other accessories just because it should be easier to get all as one piece.
Offline bigkountry
« Reply #2 on: June 20, 2008, 07:17:54 pm »
Check out www.performancetrucks.net there are plenty of super low mile LS based engines on there real cheap and they are good guys over there as well. I lean on them alot for my 01 Silverado stuff, mght save you the rebuild cost.
« Reply #3 on: June 21, 2008, 06:27:41 am »
thanks a lot for that link!  heck, i found a 4.8 for $300 off of a good member on FSC.  with only 30k miles.  i mean, i'm gonna hold out for a 5.3 or a 6.0 but heck, that is a killer deal for that 4.8...
Offline bigkountry
« Reply #4 on: June 21, 2008, 06:29:18 pm »
No problem.
Don't overlook the 4.8's (that's what I have in my 01), they peak out quick and have alot of power for their size. I have had mine tuned and it's a very stout little engine..plus it's real good on gas.
But on the other hand, the 5.3 is a big step up and the 6.0 is just plain mean.
« Reply #5 on: June 21, 2008, 08:23:21 pm »
yea, i drove a RCSS with a 4.8 and a CCSSB with a 4.8 (both 2wd) and while they seem alright (little slow to respond after flooring it but tuning would help that) i just don't think it'd have enough guts to move this truck around with authority...and if i'm gonna do a motor swap i'm gonna be proud of it when i'm done...
« Reply #6 on: June 21, 2008, 10:18:21 pm »
In light of fuel prices, you aren't going to notice an incredible difference in fuel mileage with this set up if that's the reason you are going this route.
« Reply #7 on: June 22, 2008, 07:39:37 am »
yea, VZ, you are right.  i was talking to a couple of my good friends who are also gearheads and looking at things it looks like the smartest route to go is to build the 383 like i wanted to and top it with a Holley Stealth Ram setup.  its not gonna get remarkable fuel mileage but these trucks aren't meant to...besides, i already have the 350 for the base motor and the whole build will be cheaper...not to mention i don't think that 5.3 with all it's sensors will do to spiffy when i'm going through the mucky muck...
« Reply #8 on: June 22, 2008, 10:03:56 am »
Yeah personally I'd save the retrofit for fuel efficiency purposes when something more viable and cost effective is available. You should have good reason to put in a newer GM engine, either you landed one dirt cheap or are planning on a computer controlled turbo system etc. But if you are just doing it to try and save a few pennies in mileage you're right...these trucks aren't made for fuel economy.
« Reply #9 on: June 22, 2008, 09:40:24 pm »
yea, i might find me a C10 to throw a 5.3 in...that could be a fun ride...
