Author Topic: No vacuum from vacuum advance  (Read 3709 times)
Offline buddy84GMC
    • My Sites on Cardomain
« on: June 20, 2008, 08:29:03 pm »
I have an '84 GMC Sierra with a '72 small block 400 in it with HEI.  Anyways, I wanted to check the timing with the light since I heard the valves pinging and I retarded the timing to 4 degrees advanced from I think it was 8.  The truck runs a little slugier, but I guess that what happens when you retard timing and want to run 87 in it.
My question is that I had no vacuum at idle coming from the carb for the vac. advance.  I did get vacuum when I revved it, but I thought I had to unplug the vac. advance to check the timing and this is when I noticed no suction.  I have 2 ports for vacuum off the carb, but the other is for something else...  Is it normal to not have very much suction from the vac advance when in idle?  Thanks a lot.
The truck runs great now with no hesitation or pinging, but I was curious about that suction.
1984 GMC K1500 8" lift, 39" MT Baja Belted tires, 400 small block
2006 GMC Sierra 1500 SLT 4x4 L33 5.3L Special Edition
1967 Lincoln Continental Coupe Hot Rod, 462 big block
Re: No vacuum from vacuum advance
« Reply #1 on: June 20, 2008, 08:50:28 pm »
Hook the vacuum advance to manifold vacuum rather than ported vacuum and adjust your idle speed.
Valves don't ping. Pinging is the sound you are hearing from either preignition or detonation or both. If you have to excessively retard the timing to make it run on pump gas, make sure you are using the correct spark plug heat range and maybe it's time for a good decarbonizing or some top engine cleaner.
Offline Fast68Chevy
  • I am THE Fast68Chevy!
« Reply #2 on: June 22, 2008, 01:56:16 pm »
each engine and each distributor is different and unique
you will have to set the timing and use whichever vacuum source for the vacuum advance as needed to set the engine timing correctly
sometimes i have an engine that runs correctly without vacuum advance at all
each is different, i have found
i use a vacuum guage to set the timing usually
without vacuum advance connected
and then i go from there after restarting it and making sure that it is not too far advanced initially(slow cranking speed is a giveaway of this problem)
good luck
1967/68 C30 dually truck build frame up currently.  1975 C20 YE9 pickup longfleet 96K original miles DD.  and tractors and more trucks.
