Fuel Systems and Drivability
fuel reg
Topic: fuel reg (Read 18221 times)
mikewb
fuel reg
June 23, 2008, 05:34:27 pm »
im putting a carbed motor in an 88 chevy truck. im just going to run a regulater on the line and to the carb. what should i do with the other line? seeing as how there two of them run to the throttle body?
Re: fuel reg
June 23, 2008, 07:16:52 pm »
Yuck, you should really keep it efi. But a regulator with a return would be ideal rather than trying to choke off the pump.
⌠ŻŻŻŻŻ' [☼===☼]
Re: fuel reg
June 23, 2008, 08:07:44 pm »
I agree with Vile on both accounts
camdenoilchange
Re: fuel reg
June 23, 2008, 08:10:48 pm »
i put a mallory regulator in my 89 s10 when i went from a fi 4banger to a carbed sbc. it had a port on it for the return line. got it through summit racing for about $80.
mikewb
Re: fuel reg
June 23, 2008, 09:47:19 pm »
i have a regular regulator with inlet and outlet. can i just leave the return line open?
78 Chevyrado
Z62 ON-ROAD
Site Supporters
Re: fuel reg
June 23, 2008, 11:57:14 pm »
Without the return line hooked up you will burn up your elec. fuel pump. Advance has a holley regulator you can buy for around $35 or so.
camdenoilchange
Re: fuel reg
June 24, 2008, 08:28:18 pm »
Quote from: mikewb on June 23, 2008, 09:47:19 pm
no. you will need one with a fuel line return provision.
mikewb
Re: fuel reg
June 25, 2008, 09:19:05 pm »
what if i plug the return line off. it will burn my pump up?
Re: fuel reg
June 25, 2008, 09:24:24 pm »
Theoretically the pump will work harder until line pressure rises high enough to open the dump valve back in the tank. You'd be better off just running a $15 mechanical pump
⌠ŻŻŻŻŻ' [☼===☼]
fuel reg
