Author Topic: header leak  (Read 6267 times)
Offline hotrod24
header leak
« on: June 24, 2008, 09:16:32 pm »
i was moving my truck today and i seen some oil coming out of the left
 header where the exhaust bolts up what could be wrong i have open headers
« Last Edit: June 25, 2008, 01:16:39 pm by hotrod24 »
1978 pontiac grand prix...
Re: header leak
« Reply #1 on: June 25, 2008, 12:03:25 pm »
Is your valve cover gasket leaking?
Offline TexasRed
Re: header leak
« Reply #2 on: June 25, 2008, 12:10:25 pm »
I was pulling bolts out of the exhaust manifold (drivers side) of a 1974 monte carlo in the junkyard some months ago and one was pretty oily, there may have been more like that but I got frustrated and didn't get the manifolds. It was the driver's side. I wouldn't think that the exhaust bolts pass through an oil passage. . . .
Offline Dragon
Re: header leak
« Reply #3 on: June 25, 2008, 01:05:26 pm »
That Poor thing had to have been driven into the ground, for it to blow a large amount of oil through the exhaust.....
Dusty, I with Vile on this, check your Valve Cover Gaskets.....  If you don't know how old they are, or weither they should be replaced, I would go ahead and do so.....   You can get Cork Gaskets for $5-12. and Rubber for about $12-20 depending on where you go....  Unless your Valve Covers are warped around the Flange/Bolting surface, any good gasket will seal fine....  Rubber is a bit better, as it doesn't collapse as bad Cork will with age, but it will dryout if you allow it to....   A Tip for you, an Gasket that you use, be sure to lightly coat both sides with Clean Engine Oil, that way you can reuse them each time you remove the cover till a replacement is needed(Be sure to recoat the gaskets each time you remove the covers, and Corks will last a few removals, were as Rubbers can last a few years when maintained)....
Dragon
08 Magnum-New Toy
96 Caprice 9C1-Who Knows
96 GMC ECLWB & 92 Chevy ECLWB
Offline hotrod24
Re: header leak
« Reply #4 on: June 25, 2008, 02:22:36 pm »
well i got new rubber Gaskets and new valve covers i dont think it is coming from the valve covers i put my finger up in to the header and there was the oil
Re: header leak
« Reply #5 on: June 25, 2008, 03:03:34 pm »
Well if it's coming out of the exhaust port then you're obviously consuming oil...
Offline hotrod24
Re: header leak
« Reply #6 on: June 25, 2008, 03:14:47 pm »
what can i do i just put in the 3rd set of spark plugs and it smokes out of the exhaust like crazy
Offline TexasRed
Re: header leak
« Reply #7 on: June 25, 2008, 05:22:57 pm »
when is the last time you changed the oil and is the carb running rich? You probably have to at least get new rings.
Offline hotrod24
Re: header leak
« Reply #8 on: June 25, 2008, 05:52:34 pm »
i think the oil got changed last year when i got it and the carb runs good
Offline eventhorizon66
Re: header leak
« Reply #9 on: June 25, 2008, 07:29:58 pm »
Maybe the valve seals.  Not hard to change out, just tedious.
« Last Edit: June 25, 2008, 07:33:04 pm by eventhorizon66 »
'85 C10 SWB 350 700R4 TKO600
Offline TexasRed
Re: header leak
« Reply #10 on: June 25, 2008, 08:11:27 pm »
That much oil is probably the rings. . . Change the oil, although I think the engine may be worn out. . . :( Don't get synthetic, just a decent regular.
