Author Topic: engine help  (Read 4760 times)
Offline raelayotte
engine help
« on: June 29, 2008, 10:12:01 am »
i have a 95 chevy 350 im getting oil in the coolent what do u a think it could be
Offline dumbucket1
  • Too Many Trucks
  • Coal Hauler
Re: engine help
« Reply #1 on: June 29, 2008, 10:38:48 am »
there is a few possiblities. maybe blown head gaskets, leaking intake gaskets, cracked heads, etc.
Re: engine help
« Reply #2 on: June 29, 2008, 12:45:49 pm »
I would be willing to bet it is your intake manifold. These are prone to rotting out, and I have changed may of them because of it. Main cause is improper coolant additives. The only other thing I can think of is an oil cooler, or head gasket, but if you haven't gotten it hot, I would start looking for another intake, because that is common on these trucks with the Vortec.
Re: engine help
« Reply #3 on: June 29, 2008, 03:30:22 pm »
Are you sure it's oil and not ATF? Does it have an oil cooler?
Offline raelayotte
Re: engine help
« Reply #4 on: June 29, 2008, 11:12:35 pm »
yes it does have a oil cooler
Re: engine help
« Reply #5 on: June 30, 2008, 06:19:29 am »
bypass the oil cooler and see what happens.
Offline raelayotte
Re: engine help
« Reply #6 on: June 30, 2008, 08:14:46 am »
ok i will bypass it and let u all know thanks
